Hi @Shanling I am a bit undecided on which way to go either a DAP (M3 ultra) and stop using my old Samsung Galaxy S8 or a DAC (UA5) and keep using my S8. Which one do you reckon has the better sound quality?
Shanling UA5 - Next step in our portable USB DAC/AMPs
- Thread starter Shanling
- Tags
- shanling shanling ua5
For this one I would say our M3 Ultra is better sounding. UA5 was better than original M3X, but the M3 Ultra pushes it with sound quality quite a bit further.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
@Shanling Thanks so much for the speedy reply. 1 more question does the M3 Ultra have a replay gain feature or something that can normalize sound across different tracks?
This depends on whichever app you will use.@Shanling Thanks so much for the speedy reply. 1 more question does the M3 Ultra have a replay gain feature or something that can normalize sound across different tracks?
Our default Shanling music support Replaygain
Awesome @Shanling thanks so much.
Is there any update for UA5 for it's android bug ? I have UA5 for several months, usually connect it to laptop. Now I try with android phone (S23U and Rog6), both have problem no sound. I must open the music app, play it and plug in the UA5, then I can hear the sound. I thought my dac is problem @Shanling . Check the website, no update yet for this problem. I Have no problem connect my phone using RU6
Edited,
Found the beta firmware, will try flash it. @Shanling is it possible to downgrade the firmware after i flash the beta ? where i can fine official firmware ? just in case i want to rollback to official firmware.
Edited,
jsmiller58
Shanling has a fix but have decided to not make it publicly available. You need to get it from @Shanling (monitor the thread) and will give you a link to the new FW).Is there any update for UA5 for it's android bug ? I have UA5 for several months, usually connect it to laptop. Now I try with android phone (S23U and Rog6), both have problem no sound. I must open the music app, play it and plug in the UA5, then I can hear the sound. I thought my dac is problem @Shanling . Check the website, no update yet for this problem. I Have no problem connect my phone using RU6
Here is the alternative firmware for UA5:
https://drive.google.com/file/d/1esIKIxzOnJxcWg6Us6Cz4prxnAiANad9/view?usp=share_link
We recommend installing it only if you are facing issue with Android connection (most likely Samsung, some LGs)
Otherwise stay at the default firmware.
Not possible to downgrade to original firmware.
So once i flash to alternate firmware, there is no way go back to official firmware, just in case new firmware have other bug that's not exist in official firmware ?Here is the alternative firmware for UA5:
I try UA5 on 2 my phone (all running at android 13) have the same problem
If you facing the issue, update to the alternative firmware.So once i flash to alternate firmware, there is no way go back to official firmware, just in case new firmware have other bug that's not exist in official firmware ?
I have problem using asio in foobar. Already install driver from shanling, but when i choose asio : shanling ua5, it's always error Unrecoverable playback error: Could not initialize the driver. using version 02.01.04.
If you try to run Wasapi, how is it?I have problem using asio in foobar. Already install driver from shanling, but when i choose asio : shanling ua5, it's always error Unrecoverable playback error: Could not initialize the driver. using version 02.01.04.
Using wasapi normal, but bitrate limited to 44kIf you try to run Wasapi, how is it?
Strange, I'm running it wasapi on my foobar and getting all sampling rates without issue.
Please which version of USB drivers for UA5 you installed?
I install 2 driver, shanling usb driver 5.20 and shanling usb audio driver v2.2. is it needed to install both ?Strange, I'm running it wasapi on my foobar and getting all sampling rates without issue.
forgot to mention, i play dsd file. Looking for setting, if i set in sacd to pcm, now i can get 384kbps. But when i change to dsd in sacd setting, it got distort sound. This is using wasapi, still cannot get shanling asio working.
