I just noticed the output impedance of 2.5mm on UA2 is 1.6 ohms. Why is that? Is it 1.6 vs 0.8 for SE because it's balanced and the output impedance doubles for balanced outputs or am I just speculating?
Im using ua2 with eddict player.
And eddict player has two volum controls.
Could you explain difference between maximum volume and volume in eddict player app?
Recommended to use the first volume slider to set overall volume limit (for example, to prevent too high output for IEMs).
Use the second volume slider to control actual volume of playback.
Thanks for your reply. The problem is that the iOS player app seemed to work fine and there was no warning in the software or in the online description of the UA2 about this incompatibility between the iOS version and UA2. I found the note cited by you only after having experienced the incompatibility issue.
This incompatibility wouldn't be that bad if the Android version of Eddict would support Tidal and Spotify like the iOS does (but not for UA2). Being able to equalize Tidal and Spotify content was the main reason for my purchase of the UA2. Why are Tidal and Spotify not supported under Android? Are there plans to include that functionality in a future release?
Function of Eddict Player for the UA2 is just for adjusting core settings (Volume, filter, gain, channel balance). We do not plan to be implementing any EQ for it.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
