Shanling M9 Announced - Flagship High-End Portable Player
Mar 2, 2023 at 8:43 PM Post #1,276 of 1,354
I used a USB port from my laptop to charge the player. Using the phone charger, I no longer have this problem.
USB port on laptop is probably the weakest charging you can feed the M9. So yes, using such slow charge while using M9, it would be not able to charge.
Mar 14, 2023 at 4:28 AM Post #1,278 of 1,354
Each time I turn on Airplay on my M9, it immediately turns off and an error message says “Airplay keeps stopping” - how do I get Airplay to stay on?
It was replicated and reported to software team. For some reason it shows only on M9, even when M6U and M7 received same firmware update.
Mar 27, 2023 at 1:55 AM Post #1,279 of 1,354
If I want to connect M9 to an external headphone amplifier, can I only use 3.5mm jack as the lineout?
Or can I use 4.4mm balanced jack too?
Because I have the 4.4mm jack on the player all the time, it's an inconvenience to have to swap jack's when using line out function.
Thanks.
Mar 27, 2023 at 2:29 AM Post #1,280 of 1,354
Thanks.
Does your amplifier have balanced inputs? If so, you could use 4.4mm. But it's also best to check with amp manufacturer how will the balanced input behave without grounding.
Mar 27, 2023 at 3:30 AM Post #1,281 of 1,354
Great!
Thanks.
It does have XLR balanced input.
I guess I can try that.
So lineout is not limited to 3.5mm jack only, all jack sizes can be used as line out?
Just that only 3.5mm has (lineout) next to it in the operation manual.
Mar 27, 2023 at 5:40 AM Post #1,282 of 1,354
Great!
Thanks.
Line-out mode functions with all headphone ports.
Apr 23, 2023 at 9:59 PM Post #1,284 of 1,354
Apr 23, 2023 at 11:09 PM Post #1,286 of 1,354
Apr 28, 2023 at 11:39 AM Post #1,289 of 1,354
How is the software stability at the moment on the M9? I was very disappointed with M30 software stability and gave up on Shanling for a while. Also anyone using Poweramp EQ and/Wavelet on M9?
May 1, 2023 at 11:56 AM Post #1,290 of 1,354
No issues for me iro the M9. :) but no experience with the things you mention.
As for the M30, new FW still incrementally improving. New player module to be released this year iirc.
