Any more comparisons between M8 and M9 for those that have had both?
Shanling M9 Announced - Flagship High-End Portable Player
- Thread starter Shanling
For the Singapore HFers: Stocks of the M9 has now arrived in Jaben Singapore. @Uncle Wilson has sent a nice package across.
Nice! I should be getting mine on Tuesday.
How's the wifi performance on the M9? Is it stable with no dropout/cutout?
Kiats
I have it running for just a while. No issues that I can tell thus far. Certainly nothing like the infamous issues with the AK DAPs, especially the Kann Alpha.Nice! I should be getting mine on Tuesday.
Kiats
Taking the M9 through its paces
Besides that little screen in the middle that looks a little off (a big little), looks good....
Does the “PCM…” cutout display stay on when the screen is off or do you have options for it? What can be displayed on it?
Kiats
Currently, this is what I have. No idea what else it does. Still early daysDoes the “PCM…” cutout display stay on when the screen is off or do you have options for it? What can be displayed on it?
claud W
Cut out display stays on when screen is off, but disappears when DAP is cut off.
Thanks, after looking at those pics, that dot matrix display is kind of cute and adds a nice character
Kiats
It has its charms. As @claud W indicated previously, it is really quite big. It’s about the same size as my iPhone 12 Pro Max. But about 2 1/2 times the thickness. And there is a satisfying heft to it.Thanks, after looking at those pics, that dot matrix display is kind of cute and adds a nice character
For M8 owners, whilst it is early days, the sound signature is not as warm as the M8. Still nice and musical. If I had to compare with something else in the Shanling family that I own, I’d place it nearer the M30 solid state sound signature. Hence, it can and will exist nicely alongside the M8. YMMV but that’s how I see it currently.
wahdoy
Hello Kiats,It has its charms. As @claud W indicated previously, it is really quite big. It’s about the same size as my iPhone 12 Pro Max. But about 2 1/2 times the thickness. And there is a satisfying heft to it.
I notice you also have an SP2000CU. How does the M9 compare in terms of sound quality? I have an SP2000CU and was also considering the M9. TIA.
There are options to toggle the display, however I haven’t found a way to customise what is displayed. It would be be cool if @Shanling can add some more customisation options in the future:Does the “PCM…” cutout display stay on when the screen is off or do you have options for it? What can be displayed on it?
Is anyone able to do a comparison between the M9 and the R8 ?
Kiats
@Damz87 had commented previously that he did not think the M9 was in any way inferior to the SP2K in terms of SQ. At this stage of burn in, I would agree. Are they complementary, if you are minded to hold on to both? I think so.Hello Kiats,
I do enjoy the musicality of the M9.
The jedi Baritone
For me M9 is a bit better then SP2K , not by much but I think It has a bigger soundstage,a better bass retrieval, a bit more detail ? but A hair more actually..
and much more power , the thing was close to full Fiio M17‘s power and larger battery life then SP2K on plus Bluetooth both ways and android..
MY M9 works perfectly fine yet!
