Kiats
How does M8 compare with cayin N6ii E02 or r1
Not sure if someone else in the thread still has that. But since you are in Singapore, the most effective might be to just pop by Jaben and have a listen for yourself.
JSBachFan
Formerly known as K400Lover
- Aug 4, 2014
I see several used M8s on the market and I am wondering, what people are doing. I still haven't heard about any better one ... on the musical level.And here it is! After going through all pages, finally chose this. It’s one big bulky DAP from Shanling!
Maybe they all know something, that I don't know (...yes, I have seen, an M9 is on the way, but still).
Kiats
I suspect it is a gamble that the M9 will sound just as good. Or perhaps the musical sonics are not as high a priority? Well I am still enjoying mine very much.
mRaaghava
- Sep 29, 2016
Maybe they want a DAP, that’s more fluid than M8 or they are waiting for M9 or they belong to a category of audiophiles who are very hard to get satisfied or they want a flat/neutral sound signature.
Shinigami76
Wow how you know I'm in SingaporeNot sure if someone else in the thread still has that. But since you are in Singapore, the most effective might be to just pop by Jaben and have a listen for yourself.
Kiats
Heheh! Your information shows.Wow how you know I'm in Singapore
Shinigami76
Anyway I just got myself the cayin N6II
mRaaghava
- Sep 29, 2016
Great DAP indeed. Which module you opted for?Anyway I just got myself the cayin N6II
Shinigami76
Got the E02, then added the R01 moduleGreat DAP indeed. Which module you opted for?
JSBachFan
- Aug 4, 2014
May I ask? How would you describe your Cayin combo in comparision to the M8?Got the E02, then added the R01 module
For you guys that do some streaming, how do you like it? No drop outs with wifi or anything major?
Kiats
I use my M8 exclusively for streaming. I can’t say that there is anything of note for me.
One thing you should note, though, that even AK DAPs seem to face challenges with wifi etc. I recall that seems to be a common complaint in the Kann Alpha thread. Though for myself I don’t have much issues with wifi.
Wildcatsare1
Mine is currently being replaced with a new one after warranty work, I've missed it horribly, and look forward to getting it back!!!For you guys that do some streaming, how do you like it? No drop outs with wifi or anything major?
I also exclusively use it for streaming, with no issues at all w9th WiFi, zero drops.
Awesome. Def looking a the m8 as well as some of the newer ones coming out
mRaaghava
- Sep 29, 2016
Definitely you should look at getting one. It’s a wonderful DAP.Awesome. Def looking a the m8 as well as some of the newer ones coming out
