Shanling M8 Android Portable player
Feb 21, 2021 at 9:02 AM Post #2,101 of 5,905
I did another round of testing and installed UAPP on my FiiO M15. Scanning of the 1TB card (unchanged content) took long as well - maybe 2 hours.
But afterwards everything was in perfect condition. Browsing, Restarting, tags read correctly.
So for me this is clearly a problem of the M8 not being able to correctly work with my 1TB card.
The UAPP developer (very supportive) is releaved now ...
Contacted @Shanling about the case. Let's see if the support there is as good:xf_cool:
Does UAPP play DSD natively in M8 ? I think it has been left behind for so many recent players now
Feb 21, 2021 at 9:07 AM Post #2,102 of 5,905
How can you tell? I would think it would given my understanding of how bit perfect works.
Feb 21, 2021 at 9:16 AM Post #2,104 of 5,905
What format are you using on your SD card? FAT32 formatted 1TB SD works perfectly on my M8. I tested another 1TB SD formatted in exFAT (default on many large capacity SDs) and could reproduce your problem. So I think the most likely cause is the format.
Feb 21, 2021 at 9:23 AM Post #2,105 of 5,905
It displays whether the file is playing back at resampled rate of PCM 44.1...., or 2.8M rate when using it
Looks like it works :) IMG_3325.JPG
Feb 21, 2021 at 9:25 AM Post #2,106 of 5,905
How are you liking the M8/Ely combo?
Feb 21, 2021 at 11:29 AM Post #2,110 of 5,905
All the info is right there I don't see anything in the drop down bar. Can you tell from this here whether it's been resampled or not?
I get the same - looks to me like DoP (DSD over PCM) chopped into 16 or 24 bit strings at 352.8 kHz. I play DSD through my Gustard A18 DAC this way... So DSD and not resampled, per se.
Feb 21, 2021 at 12:20 PM Post #2,111 of 5,905
Thank you! So there is hope.
Mine was indeed in exFat. So I reformated and I am just copying everything back again. Guess tomorrow I can tell the results.
Feb 21, 2021 at 12:35 PM Post #2,113 of 5,905
So I've been puzzled by this too since joining the UAPP camp. On the top, by the battery indicator, I see 352.8kHz. I expected 11.2MHz or DSD indicator there. This is the same whether I have bit perfect on or off. Are you saying that the system still sees this as 352.kHz but the DAC is interpreting it as DSD stream?
Is that why I also get stuttering when bit perfect is on?
Feb 21, 2021 at 1:16 PM Post #2,114 of 5,905
I remember that Shanling said only Shanling player can play DSD files natively. All the other apps will need to convert them to PCM first. I believe that the situation applies to UAPP as well.
Feb 21, 2021 at 2:08 PM Post #2,115 of 5,905
Neutron should be able to play dsd natively. I am just saying that Neutron is the real hi-res supporter here. UAPP is more like for smartphone stuff lol
