Shanling M6 Ultra - 4x AKM AK4493S DAC, Snapdragon 665, Android 10 DAP
Oct 18, 2023 at 11:38 AM Post #826 of 873
... but... but.... wifi is terrible, can not stream, just updated to 1.3 but same.... any ideas? Cheers !
Shanling promised to provide a network fix with the next update - but we are waiting for it already some time...
Pls. provide details about your router to help to fix the issue - as it happens only with some routers.
Oct 18, 2023 at 2:14 PM Post #828 of 873
Please what exact issue are you facing? Speed, distance, connection at all?
What modem are you using and what's its setting?
Oct 18, 2023 at 2:16 PM Post #829 of 873
Problem is overall connection: can not connect at all some times, if get really close to the router M6 Ultra connects with very low speed. my router is TP link archer80 in access point mode. thanks all for any asistance.
Oct 18, 2023 at 9:46 PM Post #830 of 873
Yeah, this doesn't sound normal, especially the distance issue. This is not the bug others describe.
Can you try to connect it to hotspot on your phone and see how it performs.
Oct 19, 2023 at 2:48 AM Post #831 of 873
Oct 19, 2023 at 10:52 AM Post #832 of 873
Connecting to my phone works well. but is not a set up I want to use.
Anything I should change on my router settigs? picture above
thanks.
Oct 19, 2023 at 9:22 PM Post #833 of 873
thanks.
You can try different WPA setting, just for a short while to see if it has any effect. But that's not something that should affect the working distance.
Oct 24, 2023 at 9:55 PM Post #834 of 873
I tried different settings on my router, got some improvement, marginal. Can not stream losseless in apple music trough out the house... but apple music defaults to losseless: the sound quality degrates :frowning2: compared to when I`m really close to the router. Pretty bad I`m using this very capable dap with no losless or hi-ress as apple mucis now offers.
an ETA when this wifi bug will be fixed ? any router brand you can recomend tha will be more compatible with this M6 ultra? I`m willing to buy a new router just to make this work.
Oct 30, 2023 at 1:53 AM Post #837 of 873
Nov 2, 2023 at 12:51 PM Post #839 of 873
Time to install Shanling M6 Ultra Firmware V1.35
Update Notes for M9 Plus/M9/M6 Ultra:
1. Fixed Roon ARC Compatibility
2. Shanling app – Fixed issue causing unresponsiveness during playback
3. Shanling app – Added more customization to Skins
4. Other fixes and improvements
Let´s see, how it works.
Nov 2, 2023 at 1:28 PM Post #840 of 873
Google Drive(0.9GB)
Its a trap! :relieved: Who are you? I don't click on links from unknown sources.
