Shanling M5s Firmware V3.4 notes
You can now update with OTA update or download from
Google Drive or our
website
New functions:
1. Added ReplayGain function. Go to Playback menu to enable.
2. Added Playlist Import / Export function.
Notes:
Works with .m3u playlist files.
Playlists will be exported into “_explaylist_data” folder in root folder of Micro SD card.
To import user created playlists, put .m3u file into “_explaylist_data” folder in root folder of Micro SD card and click “Import playlists” in Playlist menu.
We recommend to export one playlist from your M5s and follow its formatting for user created playlists.
3. Added quality settings into Tidal app.
4. Added new theme (Theme 2)
5. Album cover and lyrics can be downloaded from internet and added to currently played file.
Note: Tap on now playing screen and tap on last icon on right (icon of CD).
Changes and fixes:
1. Improved Equalizer performance, limiting distortion when using high level of adjustment.
2. Album browsing submenu now recognize external jpg files as album covers.
3. Playing interface can be quickly changed directly on Now Playing screen. Tap icon in upper right corner.
4. All Songs browsing now shows Artist name.
5. Added date setting. Date is displayed on lockscreen.
6. Improved performance of Lyrics function.
7. Fixed problem of unit not charging to 100%.
8. When Sleep timer is set, system wait until currently played song ends and then automatically turns off.
9. Optimized screen brightness, now can be set for lower level for use in night.
10. Improved font files to avoid problem with some special symbols from different world languages.
11. Other bug fixes.
