Shanling M5s now with TIDAL - Dual AK4493EQ DAC, fully balanced, Wi-Fi, 2way LDAC BT, 3.2 Touch screen, FW 3.5
Discussion in 'Portable Source Gear' started by Shanling, Aug 14, 2018.
140 141 142 143 144 145 146 147 148 149
151 152 153
  1. vodanhkhack
    Yes, I have to go back to fw 3.3 because of EQ! EQ-ed sound is much much less energetic, less dynamic and narrower sound stage! !!
    mark88888 likes this.
  2. czaps
    @Shanling my front glass in shanling broke after falling. Is replacement possible?
    I have consciously bought this product with its disadvantages. But the fall was from only 20cm and because of its slippage. No matter what can you do now?
  3. defbear
    I did an OTA update from 3.0 to 3.4. The update went fine. But oops! What the heck is up with the EQ? When I turn it on, the volume drops by half and sounds dark and congested. And you can EQ up to the sky’s but you need to raise the volume way up to hear and it still sounds awful. And if you turn EQ off, the volume returns to normal and Blasts your ears out. This EQ is not just broken but is DANGEROUS. Shanling needs to reverse this EQ “update” immediately before REAL DAMAGE is done to someone’s hearing!
  4. defbear
    Will somebody please explain Replay Gain? If I turn it on for Track the volume drops to half and sounds dead like the EQ. If I choose Album the volume returns to normal. Is this broken as well. I love my Shanling products. But 3.4 seems a big downgrade.
  5. defbear
    I dropped down to 3.3. EQ working as before but with a nice display of db’s as you move the a column up and down.
  6. Shanling
    We added this cover art function to see how it will be working, there should be future adjustments to this function.
    With EQ, sorry for this, need to look into it. Apparently software team was trying to fix distortions when used high levels of EQ and meanwhile messed it up in different way.
    You can contact your local distributor and they can order replacement screen from us. Or you can buy it directly from our dealer Shenzhen Audio https://shenzhenaudio.com/products/...reen-battery-for-m5s-hifi-portable-mp3-player
    Looking into these problems. Can you check, if any of your files don't have some preset ReplayGain that's messing this up?
    Shanling Have any question about our players? Just PM me or send me email. Stay updated on Shanling at their sponsor page on Head-Fi.
  7. defbear
    DBL Post
  8. defbear
    I have no tags set for Replay/Gain
  9. holsen
    Here's another one that has to revert the firmware.
    But first things first. I want to thank you @Shanling for continuing to invest time and effort to support this device. I have loved it since my first day with it and my fondness for this device has caused me to pick up an UP2 and soon to be an UP4.
    SInce the very begining, the only issue I've had with the M5s has been the EQ - and I've always found a way to make it work, coming up with 3 Custom EQ Settings: #1 for the car, #2 for Xelento IEM and #3 for Tin P1. So from that perspective, everything has worked fine. Not optimal, but workable. I think the issues with the new EQ are well documented now and you have acknowledged, so I dont need to write further here. I Love the new playlist import and export functions - well done on those.
    BUT, I'd like to clairify what the update / firmware history has been. I will downgrade until the new EQ issues are addressed but if the current FW is 3.4, what is the previous version, 3.3? If so, I can only find 3.1 and earlier on the download page.
    Please @Shanling confirm the most recent FW version and if it's higher than 3.1, please add it to the download page so we can download and instal until 3.5 is available. Thanks!
  10. holsen
    where did you find 3.3, on the site I can only get 3.1 as the most recent before 3.4. Thanks
  11. bendezar
  12. Shanling
    Sorry, our IT guy sometimes forgot to update the history section.
    If anybody needs, here is V3.3 https://drive.google.com/open?id=1TEnRhQjoCoLLmmh7t5c27gKpGhWwi5mo
    fusserg likes this.
  13. holsen
  14. vodanhkhack
    Oh @Shanling thank you so much for your gift : Christmas Special Edition FW 3.5 !!! Merry Xmas everyone!
    kalibur likes this.
  15. Shanling
    Small Christmas update for M5s:
    1. Added new themes, including special Christmas theme. Now 7 in total.
    2. Adjusted Equalizer performance
    Download from our website, Google drive or use OTA update
    vodanhkhack and crabdog like this.
151 152 153
