VintageFlanker
Updated with detailed specs. Cheers
Hi Shanling, Does the M5 have got a USB DAC function? Thanks.
Is it possible to use the M2/M5 as a backup battery via USB?
Nope
Good question sledgeharvy. I'm burning the L3 in with MEE P1 as we speak. Give me some time, and I'll let you know. Out if the box, I think I prefer the Shanling DAPs -especially the M5.
L3 has a warm/thick sound sig with rolled-of upper end by default. Switching to Rock EQ pushes the mids back and makes it sound a bit leaner. Jazz EQ sounds lean and tight with a lot of upper end definition. I'm bouncing back and forth between Normal and Jazz EQ right now and would honestly like something right in between. Hopefully burnin will help.
There's no way L3 can touch M5 IMHO. Maybe M2. Maybe...
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Are there any US dealers to purchase from or is it only direct?
I just checked and it is available on Amazon.
Cheers!
-HK sends
The Amazon seller is a Chinese Audio company and it ships by DHL. I would rather consider a US Dealer in the event any service is needed.
