Shanling M3X Portable Player - Our smallest Android Player
Mar 25, 2021 at 10:02 PM Post #376 of 2,511
Hey do the m3x have a standby or sleep mode? @Shanling
To same degree as any other Android device. There is no special custom sleep mode, but you can just leave it turned on and if there isn't any sneaky app running in background, you are getting just little battery loss.
Mar 25, 2021 at 10:41 PM Post #377 of 2,511
Really intrigued about this as a more portable alternative to my M8. What is the battery life on balanced? Is the SQ (particularly the bass) up to Shanling's usual lofty standards?
Mar 25, 2021 at 10:42 PM Post #378 of 2,511
Don't know if you've seen it, but the first review is up and it looks promising. M3X review
Mar 25, 2021 at 11:53 PM Post #379 of 2,511
@Shanling what is the max SE power output? cannot find it anywhere.
Mar 26, 2021 at 2:21 AM Post #380 of 2,511
Mar 26, 2021 at 4:53 PM Post #382 of 2,511
You need to put your Playlist into the Playlist folder of Shanling app.
On internal memory - "shanlingApp" - "Playlist". Just copy your m3u playlist there and then in the Shanling music app go to playlists and click on the Import playlist icon(second from left).
Please make sure that you have your playlist formatted correctly. Best to create one playlists in the app, export it and copy its structure for your other playlists.
When @Shanling is going to include Recently Added as a internal playlist. I think the mo has it
Mar 27, 2021 at 12:20 PM Post #383 of 2,511
So it appears Shanling won't have to worry about competition from Fiio any time soon in the mid-tier market. The M9 is discontinued and no replacement planned for quite awhile. In fact Fiio's mid-tier DAP's are all in limbo likely for some time. So a great time to release the M3X and any other planned models. Grab as much market as you can while Fiio is in disarray likely for all or most of 2021.
Mar 27, 2021 at 1:38 PM Post #384 of 2,511
Did they all use some form of AKM chip?
Mar 27, 2021 at 1:41 PM Post #385 of 2,511
Great feedback there. Are you still experiencing distortion on the 3.5mm output or has this gone away?
Thanks! I need to contact Shanling about it but I'm guessing the single DAC mode uses just one of the dual DAC chips, which the Schiit Magnius also did for its SE, which measures worse than its balanced out. Not sure if it is the case but it does sound like it. Fortunately the M3X is flexible enough to let you get the benefit of high gain and both DAC chips, which doesn't bother me in my casual listening with my unit. Still gonna reach out to them about it, of course.
Mar 27, 2021 at 1:54 PM Post #386 of 2,511
It's correct, only one DAC from the SE connection.
Mar 27, 2021 at 2:29 PM Post #387 of 2,511
Makes sense. Do you know if the dual DAC option in the notifications bar actually works in SE? Turning it on seems to make a difference but I haven't tested it out, to be sure placebo effect isn't at play.
Mar 27, 2021 at 2:35 PM Post #388 of 2,511
Yes, it is possible to enable Dual DAC in the SE Ouput which is why Shanling lists 3 levels of expected battery life...... SE, SE Dual DAC, and Bal...
Mar 27, 2021 at 3:17 PM Post #389 of 2,511
Oh duh, I forgot about that, my bad. It's been a long week. Balanced is effectively Dual DAC + High Gain, right?
Mar 27, 2021 at 3:28 PM Post #390 of 2,511
Kind of... Balanceed will give you higher gain and within that, you should be able to select between high gain and low gain. So to get the full 245mw you need to be plugged into the Balanced out and high gain selected.
