We should have announcement soon on the availability of M1s. Meanwhile, please keep in mind that our international prices are always a bit higher than Chinese mainland pricing.
Here you have full specification:
Dimensions: 72 x 69 x16 mm
Weight: 106g
Screen: 2.8-inch 640*480
DAC: ESS ES9038Q2M
Digital filters: 7
Amplifier: 2x Ricore RT6863
Battery Life: 14.5 SE / 10.5 BAL / 26h Bluetooth
Battery: 2100 mAh
Memory: MicroSD card slot, up to 2TB
Output: 3.5mm SE and 4.4mm BAL
Bluetooth: 5.0
BT Transmitter: LDAC, aptX, AAC, SBC
BT Receiver: LDAC, AAC, SBC
Wi-Fi Support: Tidal, Airplay, DLNA, OTA Updates
Hi-Res support: Up to 32/768, DSD512 and MQA
3.5mm Single-ended Output
Output power: 144mW@32 Ω
Frequency Response: 20Hz-40kHz (-0.5dB)
THD+N: 0.0007%@32Ω(
A-Weight@0.5V)
Dynamic range: 123dB@32 Ω (A-Weight)
Channel separation: 76dB@32 Ω
Signal-to-noise ratio: 122dB@32 Ω(A-Weight)
Noise floor: 116dB (A-Weight)
Output impedance: 0.4Ω
4.4mm Balanced Output
Output power: 245mW@32 Ω
THD+N: 0.0008%@32Ω(A-Weight@1V)
Channel separation: 108dB@32 Ω
Signal-to-noise ratio: 118dB@32 Ω(A-Weight)
Noise floor: 110dB (A-Weight)
Output impedance: 0.8Ω
