Alpc
- May 1, 2008
Well, I have been using playlist to play my songs for the past 2 days. As the software in M1 is the same as FiiO and the others (Hiby Music), I followed instructions in my google search to create playlists, using foobar2000, for my sd card and saving it to m3u8 format and place them at the root folder of the sd card.
On M1, I load it by selecting the playlist in the folder browse, it does play the songs according to the playlist. So it does work, but not from the playlist selection in the player.
Hope that helps.
Hope that helps.
