I'm using it with a Toshiba M203 256Gb, had a Toshiba M303 128Gb before. Never had a problem with these as of yet.I have decided to buy the M0, any advice on the size or make of SD card to buy or avoid?
Shanling M0 - Smallest Hi-Res Portable Player - New Firmware V3.6
- Thread starter Shanling
- Tags
- dap ldac shanling shanling m0
afico
- Jan 4, 2010
compared with Hiby r3...who has the edge in terms of clarity of the highs and soundstage?
Stenso
I have an issue, the seal on the SD card door has snapped. It isn't a major problem but it is annoying because the door will not stay shut. Does anyone know where i can get a replacement?
Where can I download old firmware versions? This bug is unbearable.
What bug?Where can I download old firmware versions? This bug is unbearable.
On their website they have links for the different firmware revisions.
http://en.shanling.com/download/56
Nolbert0
I also reverted to an older version because I use the BT receiver quite often.
@Shanling is it possible to have EQ while being used as a BT receiver in a future update?
Memory leak or whatever it's called (when the screen becomes unresponsive). And you have to restart, sometimes once, sometimes many many times. Yesterday I was resetting it for like 10 min before it let off and it was the last straw.What bug?
Thanks. I checked there before writing my post and didn't see it. Turned out my adblock blocked that archive part lolOn their website they have links for the different firmware revisions.
What changed in regards to the BT support? I didn't have any issues with it, but i don't use EQ, so maybe there's that.
That happened to me only when trying some DSD files, but I only used them for testing purposes, since I don't plan on using these on the go anyway. But yeah, this is something they need to look into,. This only happened to me when using the Artist search, using the folders was fine.
I have around 1k files, only mp3 320 kbps without any metadata. I listen music mostly from the Recent tab.
xzoro778RC
- Sep 2, 2015
The AC adapter and DC01 were connected via a PD compatible adapter, but only those who recognized first could use it.
Can this be used simultaneously in firmware?
iBasso DC01 was connected to Shanling M0, but the battery lasted only about 2 hours.
In the user manual, it's described that the M0 wasn't meant to be used with DACs/amps that aren't self powered. I believe your dongle falls in that category.
If anything, on 3.1, i wished i could send commands to my smartphone using the double and triple clicks, but I know this has been discussed, and hope Shanling will put out another great update soon.
That's unfortunately bug that was introduced around time software team added lockscreen/animations for BT receiver. Still awaiting fix for this stupid problem.
Main thing is to buy from a reputable retailer. I always buy from Amazon (the company, not the marketplace).
With SD Cards, if it looks to good to be true then it most likely is. Avoid 'bedroom cowboys' as they are going to be reprogrammed rejects and will give a much lower capacity than stated (if they work at all). Good brands that I have used include Samsung, Sandisk, Kingston, Transcend, Integral...
With Amazon and their different fulfillment ways, even buying directly from Amazon is not completely safe. We recommend to buy from oldschool reliable places(mainly trusted camera shops or big electronics chain stores).
Normally we partner with Shenzhen Audio for shipping of spare parts. Will check with them to put in also replacement card covers. (but it can take a little while).
Not likely.
Unfortunately M0/our system is not built for such connection.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Nolbert0
Not likely.
Thought so. No biggie
Can I get a replacement for my defective USB cable (see previous post, it was what was keeping me from uploading files directly)?Normally we partner with Shenzhen Audio for shipping of spare parts. Will check with them to put in also replacement card covers. (but it can take a little while).
Total: 9 (members: 0, guests: 9)
