tjl5709
I recently decided that apart from my usual portable setup, I wanted something specifically tailored to training: as small and light as possible, and still with great sound. I might turn it into a small review series, as it is really interesting to explore what works well for training. My first setup is the Shanling M0 paired with the Final E4000. Great sound with lots of energy and details come through very well, even when running outside.
I have used this for a couple of trainings so far and really like it. I don't (yet) have the clip and found that I could easily put the M0 in the back pocket of my running tights (usually meant for keys, etc) and run the cable along my back. Worked perfectly!
Now I have run into one issue that might, or might not, be possible to solve easily. I had created a carefully selected playlist on my AK70 and even went through the trouble of ordering the tracks so that there was a build up in the music that worked well for strength training. When I created the same playlist for the M0 the tracks ended up in a completely different order (not in the order I added them). Is there a way to arrange the tracks of a playlist?
For this DAP, I only use MP3 files so with a 256 gb card I have lots of room. What I have done is to create a new "album" in my managing music software. I use mediamonkey. I then create a new Genre. I put all my new "albums" in this genre, and now I can have multiple playlists to run. Yes it duplicates files, but mediamonkey makes it easy to manage, and these simple DAPs are far easier to operate thru albums and genre than thru playlists.
