Yes, it's a great match with the IT01.Hi all, couple of questions before I potentially take the plunge on the M0.....
1) ibasso it01 are reported as a good match?
2) am I correct in thinking no hiby link / control from smart phone?
3) no issues with class 10 SD cards?
Ok, 3 questions
Cheers
Shanling M0 - Smallest Hi-Res Portable Player - New Firmware V3.6
- Thread starter Shanling
- Tags
- dap ldac shanling shanling m0
DrumSeb
Still the M0 doesn't work with the Mojo ? My Sd card is formatted to Fat32, and 2.2 firmware ..
Hey guys. I recently got the Shanling M0 'DAP' along with a pair of Brainwavz B400 in-ears. I have been using the B400s with the M0 ever since I got them both, but right from the start, ever since I started listening to music with them (even the first 20 minutes), the B400s have been letting out a 'burning' smell from the shells, through the open nozzles. My question is, could a 'DAP' cause any pair of headphones like these to do this? I mean, could the Shanling M0 be the reason I'm experiencing the burning smell? Also, should I be alarmed and stop using the B400s with the Shanling M0 DAP at all? I don't want them to stop working eventually, and I think the burning smell is a stage of that. Please help me, thanks.
rdale
I use the Shanling USB C to micro USB cable with my Hugo and it works greatStill the M0 doesn't work with the Mojo ? My Sd card is formatted to Fat32, and 2.2 firmware ..
DrumSeb
Humm ? any suggestion, i have no idea why it not even recognize the mojo..I use the Shanling USB C to micro USB cable with my Hugo and it works great
rdale
Are you using the Shanling cable? If not I would suspect it is a cable problem. I use the M0's USB output with my iFi iDSD Nano and Micro too and it works fine with them. I've found my Hugo's Micro USB input is more cable fussy than other inputs on other DACS though.Humm ? any suggestion, i have no idea why it not even recognize the mojo..
DrumSeb
I have a moon-audio silver Dragon micro to micro. Dont have this issue with my AK70 or Macbook pro... I will try then..Are you using the Shanling cable? If not I would suspect it is a cable problem. I use the M0's USB output with my iFi iDSD Nano and Micro too and it works fine with them. I've found my Hugo's Micro USB input is more cable fussy than other inputs on other DACS though.
greatwhite58
Isn't the M0 usb C and not micro usb? You state that you are using micro to micro cable and I'm sure M0 is usb C.I have a moon-audio silver Dragon micro to micro. Dont have this issue with my AK70 or Macbook pro... I will try then..
DrumSeb
Yes But im using a adapter, micro to Usb-C.Isn't the M0 usb C and not micro usb? You state that you are using micro to micro cable and I'm sure M0 is usb C.
My guess is that either the adapter or the cable needs to be OTG and neither of them are. A standard charging/data transfer cable won't do it.Yes But im using a adapter, micro to Usb-C.
should I buy uhs 3 card or uhs 1 is enough for shanling m0? $3 gap between uhs3 and uhs1 with same capacity
Idk whether shanling support anything higher than uhs1 card
[QUOTE = "SwordNoob, příspěvek: 14619258, člen: 501681"] Měl bych koupit uhs 3 kartu nebo uhs 1 stačí pro shanling m0? $ 3 mezera mezi uhs3 a uhs1 se stejnou kapacitou
Idk, zda shanling podporuje něco vyšší než karta uhs1 [/ QUOTE]
Pomalejší karta stačí.
A slower card will suffice.
It works with Mojo from very beginning. I would advice to firstly try to get cheap USB-C OTG adapter(with USB A on other end), and try basic USB cable. We have in office some random 1USD adapters and work just fine.
Or get the Shanling L2 cable
Easiest thing is to try your Brainwavz with different device. M0 doesn't have power to make any headphones start burning, even at 100% volume.
No reason to get higher UHS for M0.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
DrumSeb
Thank you, i try the same moon-audio cable micro to micro with adapter USB-A to USB-C and it work well now. Micro to usb-c doesnt work ...It works with Mojo from very beginning. I would advice to firstly try to get cheap USB-C OTG adapter(with USB A on other end), and try basic USB cable. We have in office some random 1USD adapters and work just fine.
fingertrouble
I'd get the fastest card you can afford.
Pretty sure Shanling will use any (I've got a UHS-I Speed Class 3 Samsung Evo in mine -guessing you mean UHS-I Class 3 and not UHS-II or UHS-III which I'm pretty sure are different things, cos UHS-II and UHS-III cards aren't that cheap! The U with a number inside is the class, look for a I II or III on it for actual bus speed, or indeed UHS-II or III will have extra rows of pins on the back. Check this to explain why https://fossbytes.com/uhs-ultra-high-speed-interface-difference-uhs_i-uhs-ii-uhs-iii/). UHS is usually reverse compatible with SDXC and SDHC devices.
The reason you should get a Class 3 UHS-I over say Class 1 is not that the DAP will need that, but you'll spend ages copying files over on your computer. It's faster with a SD card adapter/card reader, but still limited by the speed the card is at. So if you want to move gigs of files regularly, go for the fastest class you can afford.
Of course if your card reader doesn't support UHS-I etc then it's wasted...Also transferring via the DAP is the slowest way, I only do that for a few files cos it takes an age - and of course doesn't take advantage of the faster card.
Total: 26 (members: 0, guests: 26)
