- Sep 28, 2016
No. And why would you want that? Just use it as usb dacHi all
is it possible to use the M0 as a USB DAC and LDAC transmitter at the same time? Trying to stream LDAC from my mac to the cans.....
Store the music in the m0 and transmit direct? Why bother connecting to the Mac? Also, it would be easier for me to be notified of your reply if you use the quote buttonI'd like to stream music from my library to the cans while away from the desk. Using LDAC.
Haha, it's so obvious. I've seen more than one trying to go through all kinds of hoops. Just use a microSD, lossless audio files and wired headphones for the easiest, most stable and best experience. In my opinion.Store the music in the m0 and transmit direct?
Have you even considered it's simpler not to transfer/store to M0 every-time you want to listen to something from the MAC music library?Store the music in the m0 and transmit direct? Why bother connecting to the Mac? Also, it would be easier for me to be notified of your reply if you use the quote button
The point being that he has posted that on several occasions. That was my point.Then all he has to do is post that, at least it is a response on the question and I will stop bringing it up. But to continuing to answer other posts which is great how hard is it to post, fw update in progress unable to provide eta at this time.
How big is his library anyway? I personally prefer to store all my music in separate SD cards, organised by genreHave you even considered it's simpler not to transfer/store to M0 every-time you want to listen to something from the MAC music library?
I think he wants the LDAC function wirelessly to stream directly from his library.
Yes I agree! I did try to post a photo by clicking on the icon with mountains in the Reply to Thread editing box, but it didn't have a file selector so I could find the .jpegs on my file system, it only had a URL for images that are already on the web as far as I can see. Maybe because I'm a Head Fi newbie who has only posted a single message, the option hasn't been enabled for me yet.
M0 pairs nicely with the Mobius - LDAC is dang good sounding...just got the Mobius in today:
Is there any way to connect it directly via USB-C and have volume control? It works via USB-C, as in it it plays the music - but absolutely no control of volume from either the M0 or the Mobius, with both turned down to their minimum the sound is still at maxmimum output and LOUD... smooth though... smoothest most pleasant deafening loudness I've ever heard.
Yep. Bought a pair of sony wireless headphones in a recent sale and didn't like em. Too much faffing about. Just plug in headphones press play job done.
