Hi, it shows just bluetooth icon (even though my preferred setting is LDAC-HQ in the bluetooh settings)
I also have Sony
SRS-XB31 portable speaker which has LDAC. Same with that as well. Just bluetooh icon.
If it only shows BT icon, there is some prioblem with pairing, I would advice trying to pair them again, try jumping through codecs, if they connect with any of them.
guys i found a little bug..i have a playlist with 20 songs from when im running and when i try to delete a specific song it says removed but it wont dissapear from the playlist...when i play the playlist i dont hear the song i deleted...it happens with other songs too from other playlists...its not a problem at all just thought i should share it..
I wasn't able to replicate this error, any song I deleted disappeared from playlist immediately.
@Shanling Is there a way to display the Playing Song Information when I connect the m0 to my car via bluetooth. At the moment it only shows m0 on the car display but when I use my Sony A45 I am able to get the song information on the car display.
Considering wide and ridiculous market of car stereos, it would be for us impossible to implement such function fully.
@Shanling - would be possible to enable the M0 to output via usb while receiving a bt signal? i.e being able to be able to stream from a phone to the M0 which would then pass the digital signal by usb to a dac. Thanks.
As was stated in this thread few times already, we are working on implementing such feature in future update.
@Shanling Can you remove that odd kick in the scrolling please.
What "kick"?
Just curious, can the m0 output audio to USB C headphones?
I'm going to guess they will not put out an analog signal for passive USB C headphones, but does it put out a digital signal for active USB C headphones like those that come with the essential phone for example?
I don't have a pair to test, but I'd be curious to see if they work.
Are there any passive USB-C headphones??
With active, well, it demands what are their demands on power. I know one user was using his USB Sony headphones with M1. But we did no testing with USB-C headphones,
I got mine about a week ago, and I must say I am very dissapinted, to the point I'm thinking I'm doing something wrong. I'm using Sony Wi-1000x and I think they sound amazing using my android phone. However, when connecting to Bluetooth (any protocol available) they sound really bad. Little bass, poor separation etc. Anyone else with similar experience?
If we put aside limit possibility of your M0 being somehow "faulty" in BT transmission, it's most likely some affects on your phone are changing the sound, while the flat sound of M0 shows true nature of your headphones.
You can try your headphones with different BT sources to see, if they will be closer to M0 or your phone.
Hi
@Shanling also, addition to that LDAC icon is not showing up issue, today I eralised another issue. When I go to My Music, if I click on Album, it says "update music" then nothing happens. Same for Album, Genre and Artist.
You must first update your library, Settings->update. You can look into manual on first page to learn more about all settings
They have the exact same dac/amp hardware? What's up with the "Quad dac" moniker in LG V20?
"Quad Dac" is pretty much marketing used by LG. It doesn't meant there are 4 DACs inside, it's more about internal structure of this one chip. But to masses and tech websites, quad DAC sounds impressive.
