Yes, it's just a regular 3.5 TRS M to 4.4 TRRS F.What is this adapter you are using on the second picture - is it 3.5=>4.4 adapter? I was under an impression that M0 Pro uses a proprietary adapter and therefore can be bought only from Shanling.
Shanling M0 Pro - Ultra-Portable Hi-Fi Player, Now With Balanced Output!
- Thread starter Shanling
using M0 pro make me go back to enjoy song again…
bluetooth connection is becoming crucial again, especially you have streaming apps in other device.
When I connected LDAC / SBC, Seem we can not change setting such as gain, playback etc… or I didn’t aware how to go there.
been trying to swipe to the right or left, seems not work… and I need to disconnect the bluetooth to go to that setting…
and is there possibility to arrange the music/song on other device? the display is not big enough for my fat ass finger. lol
You need to adjust settings before you enter the Bluetooth receiver mode. No way around it.
You can simply quit Bluetooth receiver by swiping right.
Arrange music? In which way? M0 pro simply shows either file orders in folder browsing, in albums it goes by track numbers and in all it goes alphabetically.
It's not proprietary connector, we were just first one to use it for such output. You can find TrrrS 3.5mm jacks on aliexpress easily.
In this case M0 pro runs single ended, like any normal device with this adapter.
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
noted,
-So changing setting must be done before the Bluetooth connections is establish...
- Arrange music, like Hiby Apps, mirroring the database in M0 Pro, so we can arrange music in our own favorites queue etc... Hope you understand what I mean.
- Another question regarding using M0 Pro as Player only, connected to DAC via USB C. Is there any pre sequence that I need to do.. seems is not something that plug and play... and often get intermittent, so the DAC will not read M0 Pro ...
edit :
The last question already solved, this is because my DAC required quite high voltage, so when it connected to higher Amps (charger), M0 Pro just easily detected...
noted,
edit :
We have SyncLink in our Eddict player app, you can use that to browse the library.
For use with USB DACs, you need to change USB mode in system settings.
You can check details for M0 Pro in its advanced manual:
https://drive.google.com/file/d/1cY3YKzEwtZU_fXWDL_gMj2Q-3qx8CxI5/view?usp=share_link
Wow... I like your fast response.. nice..We have SyncLink in our Eddict player app, you can use that to browse the library.
BTW, please also add the Advanced Manual for M0 Pro in first page, so everyone can easily access it.
Almost happy M0 PRO owner since yesterday
"Almost" - because I already know as my fully enjoing with this little enter-TiNY-er will be pain in the as.... I mean - ears, without possibility of at least fast-forward (for example during my long walkings or (much shorter) runnings, listening to mix-sets when sometimes You have to move forward through the crap tune "from the pocket" or You just don't have patience nor can't concentrate to fingering progress bar).
So, Dear SHaNLiNG, I suggest "press and hold the wheel knob to fast forward" - this is most important to me, but why not go ahead and do "double press and hold" to fast rewind by the way
I know You can do it, SHaNLiNG! I think it just a matter of the player not treating the long hold press, preceded by press or double press, as a signal to turn off and everything WiLL be just fine then (??)
Thank You in advance
There's a bit missing in the new Advanced Manual. It's on page 8. In the M0 manual, it was under the heading Double-Click. That heading seems to have gone missing but this function is still there under Volume Lock.Almost happy M0 PRO owner since yesterday
Thank You in advance![]()
It's still in the manual, as Wheel shortcuts. Just seems it's not correctly formatted to show in the list at the beginning.There's a bit missing in the new Advanced Manual. It's on page 8. In the M0 manual, it was under the heading Double-Click. That heading seems to have gone missing but this function is still there under Volume Lock.
But that's only playback control for prev/next song.
@kDbJ is asking for fast forward and rewind, which is not likely to be introduced for M0 Pro.
Aha! I see what you mean. @kDbJ has mix sets that are not split into separate tracks. Fair enough.It's still in the manual, as Wheel shortcuts. Just seems it's not correctly formatted to show in the list at the beginning.
Dvl Kubo
- Oct 5, 2016
Are you guys going make a clip for this like the original M0
Teleute
- Jan 14, 2012
Hello!
I have a Shanling M0 Pro player and Anker Soundcore Liberty 3 Pro Bluetooth headphones.
The problem is that the sound from the player is not fed into these headphones.
Pairing is established, the name of the headphones is displayed in the list of connected devices. But when the name of the codec (LDAC or others) appears in the top status bar, playback stops and is blocked (I press the Play button, it does not respond).
The headphones themselves are in good condition, with other sources they work fine. The player also works fine with other Bluetooth headphones.
Tell me, is it possible to "make friends" Shanling M0 Pro with Anker Soundcore Liberty 3 Pro headphones?
Thanks for posting this. I also have the Liberty 3 Pro so I want to know if there's issues before pulling the triggers
Also another question separate question for the people here: Can you use Synclink and BT head/earphones at the same time with it?
Igor166
Мне не удалось одновременно использовать наушники SyncLink и Bluetooth (не Liberty 3 Pro, а другие, которые подключаются к M0 Pro). SyncLink отлично работает с проводными наушниками.Спасибо, что опубликовали это. У меня также есть Liberty 3 Pro, поэтому я хочу знать, есть ли проблемы, прежде чем нажимать на курки.
Так же еще вопрос отдельный вопрос к народу здесь: можно ли с ним одновременно использовать Synclink и BT наушники/голову?
No, not possible unfortunately, M0 Pro can't work with two completely different Bluetooth systems at once.
- Jan 29, 2010
Today we look at the M0 Pro on Headfonia. It's a new recommended Buy
https://www.headfonia.com/shanling-m0-pro-review/
How could I use 2.5mm balanced headphones?
Should I use Shanlings balanced adapter with a 4.4mm to 2.5mm adapter? Any other options?
Total: 16 (members: 0, guests: 16)
