Shanling M0 Pro - Ultra-Portable Hi-Fi Player, Now With Balanced Output!
Feb 2, 2023 at 11:47 PM Post #241 of 983
1. It was adjusted this way in cooperation with our Japanese distributor, will check with them.
2. Will check.
3/4. We do not plan to add any customization for the swipes.
5. Not possible for it to scan only for newly added songs. We hope that at least we might be able to add the scan only for specified folders.
6. We are looking into adjusting it.
7. No plans for this.
8. Album artist sorting can be enabled in Playback menu, "Artist List Display"
Availability of adapters is up to the stores. They can order it from us at any time. If you want to see it at their stores, you can send send them email.
You can completely ignore the library scan if you are using just folder browsing. Just turn off the Automatic Music update.
In our testing it works just fine for data transfer from Android phones. It will show up as OTG memory. Just make sure USB Mode is set to USB Storage.
No, M0 Pro doesn't support Airplay or even any other network connectivity.
No, this adapter is only compatible with M0 Pro, it can't be used with other 3.5mm jacks.
M0 Pro is not compatible with the 3.5mm balanced cables, as they are 4-pin. M0 Pro is using a different setup of 5-pin.
M0 pro doesn't have hardware needed for "lift to Wake". Will see if we can do a double tap.
There is no microphone support on M0 Pro.
Is it happening with all files or just certain ones? We do not have Mojo2 to test, but will see what we can do.
Any place selling M0 Pro can sell the adapter. Send them message.
No update so far, was just released. You can follow us on social media or check news section of our website, we always post firmware updates there.
Thabk you, im really looking forward to a firmware update. If you are able to add double tap to wake screen and slow down the scrolling speed, I would say it's almost perfect. @Shanling, what do you think about moving the file type from the track list to the information section? There is very little space for characters on the screen and i feel the file types take up valuable space.
Feb 2, 2023 at 11:48 PM Post #242 of 983
Yeah, I had to make a custom one but I think I prefer it. Clip cases are usually plastic and offer less protection in general. I had a stainless steel clip laying around that I ordered on aliexpress some time ago and never used. Sanded the back of the clip and the leather where I wanted to attach it and used rubber cement. Hasn't even been an hour and it feels solid. Plus adds a nice groove for one of my fingers. 👍
That looks pretty good, great idea!
Feb 3, 2023 at 12:57 PM Post #244 of 983
2. Will check.
Hmm, my cars does not get recognized by Shanling m0 Pro if formatted to android usb format via the phone (it shows "USB Drive (Linux) not supported on USB OTG" and not recognized by Android Phone when formates to exFAT (which works fine with the DAP). Card itself is recognized by phone when connected via USB org via adapter, only when installed in DAP it does not work at all.
Feb 3, 2023 at 6:56 PM Post #245 of 983
Do you format your MicroSd card to work as a part of internal memory of the phone? Normal Android phones recognize exfat cards without any issue.
Feb 4, 2023 at 8:08 AM Post #246 of 983
Pre-odered one yesterday (+ adapter) :D
Feb 4, 2023 at 8:47 AM Post #247 of 983
I tested same card (Kingston Canvas) formatted as stock exFAT with my android 12 phone. It is detected as usb drive when connected directly via SD card reader. It is not recognizable when inserted to Shanling M0 Pro and connected in USB storage mode though.
Afterwards I formatted it via phone when connected via OTG in M0 to be detected as USB OTG storage and indeed it starts to be recognizable on phone. It is not recognized by M0 anymore though 🙈 I would try different card and different phone, but generally what format do you recommend? ExFAT?
Feb 4, 2023 at 12:03 PM Post #248 of 983
Why does this happen on certain files even though they have all been tagged properly and show up just fine on the Shanling Q1?
Feb 5, 2023 at 4:12 PM Post #249 of 983
looks like it is showing the file name and not reading the metadata track name. These DAP's are tag sensitive and sometimes have issues with newer revisions of metadata editors. With the Q1 I had to use a pre 2013 version of the tageditor to get the apostrophe's to show without the extra spacing on the play screen. Shanling has never been good with the handling of track metadata sticking with support for older versions.
Feb 5, 2023 at 7:49 PM Post #250 of 983
We use exfat on our cards.
If you facing any issue with tags, please send me this one file over PM or email at info@shanling.com
Feb 10, 2023 at 9:40 AM Post #251 of 983
Ok, more trouble with this pesky device. Now it seems to have died.
Won't power on. Doesn't seem to charge. No sign of life when connected to a computer.
Not even a month old. Very disappointing.
Feb 10, 2023 at 10:40 AM Post #252 of 983
Sorry to hear that, sucks big time. I guess better now than out of warranty. Any chance you can get your money back and wait for the M1S?
Feb 10, 2023 at 10:49 AM Post #253 of 983
I'm in communication with the vendor.
I’ll definitely wait for the release and reviews before any further purchases. My fault for buying a first gen device, I usually have more discipline.
UPDATE:
Two hours later the device powers on and seemingly works fine. Still unacceptable.
Feb 11, 2023 at 2:22 AM Post #254 of 983
UPDATE:
Good news I guess, any chance it had to do with sleep timer settings? It would be nice to see and explanation from @Shanling as this is the kind of issue that will hold me back from a purchase.
