Shanling M0 - Smallest Hi-Res Portable Player - New Firmware V3.6
Aug 23, 2019 at 12:54 PM Post #5,492 of 6,413
Hey guys right now I'm using my kz zs 10 pro with my ZTE axon 7 and it sounds great but if like a small dap for gym so I can free up my phone storage.
Would this shanling sound better or as good as my phone ? Any other dap you would recommend for my use case ?
Thx
Aug 23, 2019 at 4:18 PM Post #5,493 of 6,413
Thx
Not exactly the same setup - Xiaomi Redmi Note 5a prime + KZ ZS7 / Fiio M3K / Shanling M0.
Does it sound better? Mmm not sure. Each of them sounds different. Some songs I like on one of the players, some on the phone, some are awesome on the players with a bit of eq tuning. Are the players better? Maybe a bit. I cannot decide.
Aug 23, 2019 at 5:17 PM Post #5,494 of 6,413
Thanks for your suggestion and idea. I worry the clip will break or becomes brittle over time.
Kept thinking on how to use the M0 on a watchband, finally decided to make a custom aluminum piece for mine to attach on the clip system.
It's way more secure and laying a bit more flat on the wrist as it doesn't add any more thickness than the clip case.
It still rellies on the clip, though. I Guess as long as it doesn't get caught and yanked against stuff it should be fine.
IMG_20190823_222538.jpg IMG_20190823_222801.jpg IMG_20190823_223034.jpg IMG_20190823_223241.jpg
Aug 23, 2019 at 6:59 PM Post #5,496 of 6,413
Nice. However, too much metal parts may cause Bluetooth signal drop, please take note.
Aug 24, 2019 at 1:40 AM Post #5,498 of 6,413
V3.0 and 3.1, BT receiver mode is inconvenient. If the screen is off, you cannot use the wheel shortcuts.
I did explicitly mention it when 3.0 was released and Shanling sort of acknowledged it but I guess I didn't make enough noise about it at the time?
Also, upon further testing, the shortcuts do work if the controls are visible (play button in the middle) when locking. But it's safe to say, it's a feature that is currently very much broken. Disappointed by this omission as this issue was reported when the previous 3.0 update was released.
Aug 25, 2019 at 8:48 PM Post #5,499 of 6,413
It was reported to software team right away.
Aug 26, 2019 at 12:20 PM Post #5,500 of 6,413
Hey, quick question. You guys like the Shanling ME100 IEMs with the M0? Anyone has them?
Over-ear headphones are getting bulky for me, and I'm looking for something portable (but also pretty, some of the IEMs I saw are... ugh).
ME100 seem pretty nice, might go for it.
Aug 26, 2019 at 5:02 PM Post #5,501 of 6,413
They get a good review on head-fi here
Personally, I use Etymotic HF5. I listen mostly to classical music but I'm not discriminating enough to comment on how good they sound -they sound fine to me. The main reason I use them is because they're the only IEMs that I can comfortably wear for a reasonable period with the three part tips. I've tried a few others but they hurt my ears - even with the smallest tips. That might be more of a consideration than the appearance....
Aug 26, 2019 at 7:13 PM Post #5,502 of 6,413
Since it wss a while since the m0 launched, do you think Shanling has a new one coming soon? Might want to buy the m0 since it is a nice sale right now on aliexpress
Aug 26, 2019 at 7:24 PM Post #5,503 of 6,413
Read some reviews online, they claimed that ergonomics were fine, audio was very good but a bit on the bright side. I might pick the ME100 Limited Edition (Red/Blue ones).
Supposedly they pack a bit more bass which I appreciate. Haven't found one single review on this version in particular but I'm going to trust Shanling to deliver a good product.
I suppose as an introduction to IEMs they will be more than fine for me. They bring a ton of eartips so I might try and see what I like.
Aug 26, 2019 at 9:36 PM Post #5,504 of 6,413
After buying the Shanling M0, Fiio M5, and having the M2x on the way, I found the HIDIZS AP80. This has everything I was looking for: BT Transport (output to USBC with connected to phone via BT) AND the ability to control the device from my phone via HiBY Link. I'm eager to compare the AP80 to the M2x. For now, The AP80 finally scratched all the itches I had.
Here are a few other comments:
https://www.head-fi.org/threads/ap8...es-music-player.878141/page-209#post-15148990
Aug 26, 2019 at 9:58 PM Post #5,505 of 6,413
M0 also works as BT transport, just too bad it takes so long for our app to come out :frowning2:
