DatGameh
- Oct 6, 2016
Sure!Thank you!
If you could post even one here when you have time that would be greatly appreciated!!
Here ya go
Sure!Thank you!
You’re getting a touch screen on the M0 (although it’s small and takes a bit to get used tiki) and I think it sounds better imo than both the N3 and X1- N3 sounds good but I like the more neutral sound of the M0 better.
This is based on iem use, both the N3 and X1 have more output power. Oh and the M0 has a very clean output- good for sensitive iems.
I’m with barondia, I don’t think you can beat the M0 for portability and price, and with the next firmware it should be even better. I mean for a hundred bucks it’s a no brainer, I think it’s the smallest dap you can get with LDAC support.
Yeah, but earlier in this thread TheoS53 very kindly confirmed that the M0 could drive my 250-ohm Beyerdynamic DT 1770 Pro just fine, though it would need to be in High Gain to do it, which is fine. It's really pretty awesome that something so tiny can power something with such a high impedance.
I guess it depends on what constitutes ‘just fine’, No daps I’ve tried can drive my senn hd600s (properly) and make them sing like something like mojo for instance.
Can they get loud enough to sound ok? Sure they can, but they sound much better with more power- I wouldn’t even try them with M0. But hey as they say ymmv and of course it depends on the cans
Sure!
Here ya go
I guess I'd have to try it out to know for sure. I use my own custom EQs as well and which definitely adds some volume, plus my Poweramp app gets louder when I enable an option on it called DVC (Direct Volume Control). But yeah, if it doesn't suffice (the 50 ohm difference between mine and yours helps too), I would probably have to consider something that I believe to be even stronger like the Ampio G1 or else the iFi xDSD. The xDSD doesn't CURRENTLY have LDAC, however, I've been told that it still outdoes anything priced below it that does offer LDAC even with just like AAC or aptX in terms of sound. But it also costs $399. LOL
At some point I will try out the M0 I think, and if I do, of course I will post my results here.
I think the Beyers might be more sensitive too, it’s definitely a nice tiny dap with great sound. I can’t really fault it for the price, it plays music very well.
Yeah...........I think Theo or someone might've also said earlier that closed-back tend to be more sensitive in general vs. open-back.
Yes there is quite a difference between open and closed design and how they’re driven- you obviously lose more sound on the open cans.
I also have the boring black, my purple one was DOA so black was all that was left, still love it though.
