Shanling M0 - Smallest Hi-Res Portable Player - New Firmware V3.6
Oct 1, 2018 at 10:35 AM Post #3,316 of 6,418
hi guys, i just got shanling m0 with 1.0 firmware, but i can't go to 2.1.... its just restarting and blank.... is it normal? how long you guys wait till it update?
i'm already tried using 32gb 64gb and 128gb with fat32, place "update.bin" in the root
need help
Oct 1, 2018 at 12:25 PM Post #3,317 of 6,418
need help
If you are on a firmware below 2.0 then the SD card needs to be exfat for it to work. Then the card can be formatted to fat 32 afterwards.
Oct 1, 2018 at 1:25 PM Post #3,320 of 6,418
Can you take a picture if possible?
The lowest firmware I thought was 1.5 from the factory.
I got 1.0.... and i cant update to 1.5 2.0 or 2.1.... tried fat32 and your suggestion exfat... :frowning2:
Oct 1, 2018 at 1:31 PM Post #3,321 of 6,418
I thought it was the other way round, and the early firmware needs to be on a fat32 card.
Oct 1, 2018 at 1:34 PM Post #3,322 of 6,418
i'll try it.... hopefully work.....
update: still blank though after restarting... dunno its updating or not
how long the update takes?
One further thought - have you unzipped the downloaded file so that the one you're putting on the card ends in .bin?
Oct 1, 2018 at 2:39 PM Post #3,324 of 6,418
need help
Use a FAT32 formatted card.
Place update.bin in the root directory of card.
Start M0, navigate to System settings, select "System Update".
That is all there is to it.
Oct 1, 2018 at 3:25 PM Post #3,326 of 6,418
[QUOTE = "fingertrouble, post: 14512639, участник: 500704"] Сейчас играет на экране и в избранном плейлисте / недавнем. Список файлов в порядке. Но если я просматриваю художников - все эти специальные дорожки характера отображаются как Неизвестный Исполнитель. Иногда бывает трудно найти. Русские, похоже, этого не делают?
Извините, что сценарий, который я использовал для подсчета, рассматривает их как разные временные файлы, если случай отличается или усечен - чуть более 11 500?
16 MP3
29 Mp3
1 aac
9 aif
19 aiff
466 флаков
2668 м4а
8363 mp3
47 wav
Он сделал это снова раньше - обновление остановилось примерно на 5045. [/ QUOTE]At me too it was. I had to remove 100GB of music, but I found the reason for stopping the scanning of the player. I already badly remember, but in my opinion these are files (wv).
Oct 1, 2018 at 3:41 PM Post #3,327 of 6,418
Before we go on week long holidays, I have one great news for you.
We just got beta version of new firmware for M0!
It will be tested by our testing group over holidays and if everything goes smooth, we will release it when we get back.
See you again on October 8th.
Can't wait. Having fast forward/rewind and custom eq functions would make me even happier
Oct 1, 2018 at 3:51 PM Post #3,328 of 6,418
The early versions of the M0 had to be updated from exfat cards then from 2.0 and up they can be updated from fat32 cards as well. My version came with 1.5 and could only be done with exfat. If the .bin is in the root of the SD card then update from the settings menu then update and then press update again.
Oct 2, 2018 at 11:05 AM Post #3,330 of 6,418
had this problem to update from 1.5 to 2.0. Card had to be in fat32. I suppose you need to do this first. To go from 1.0 to 1.5 exfat is not accepted for this procedure
