Shanling M0 - Smallest Hi-Res Portable Player - New Firmware V3.6
Jul 3, 2018 at 12:01 AM Post #1,681 of 6,418
I would highly recommend trying the Massdrop Plus IEMs, but it is going to be challenging to find it most likely... Only sold through Massdrop (who does not accept returns, as far as I know)...
One of the rare IEMs that do not kill my ear canals.
Won't work with the BTX1 though, since it is NOT using MMCX connectors.
Yeah everything is going mmcx, so the 2 pin seems to be going the way of the dodo.
Jul 3, 2018 at 12:14 AM Post #1,682 of 6,418
U ok? It's still going strong, it's way more popular among ciem manufacturers. Mmcx ismore common among cheaper iems cos its cheaper to use
Jul 3, 2018 at 1:23 AM Post #1,684 of 6,418
Yeah I’m ok, you ok?? Let me rephrase that then... it’s going the way of the dodo on universal iems. Which is what most people use :wink:
Empire ears? Jomo? Kinera? Massdrop plus?
Jul 3, 2018 at 1:35 AM Post #1,685 of 6,418
Shure, Westone, mee pinnacle, sennhieser, beyerdynamic, ibasso, Fiio, Sony, orivetti, campfire, hi fi man, UE, and on and on and on.
If I listed every model that used mmcx connectors I’d be writing all night. So your argument isn’t winnable, you must realize that? Now I’m not going to waste any more time on your silly ass. Next time engage your brain before you write something that makes you look utterly stupid.
And I wouldn’t have had to open a can on you if you would have engaged me like a normal coherent, functionaly cognitive person. Instead of starting your reply with U okay? I just don’t have time or patience for retardedness.
Jul 3, 2018 at 1:41 AM Post #1,686 of 6,418
2pin might be popular among small high-end Ciems (and I still really prefer it over MMCX), but significant rest of market, all major manufacturers, are on MMCX.
Jul 3, 2018 at 4:14 AM Post #1,688 of 6,418
Some small update for you guys, nothing major, small fixes to BT receiver mode and to the system overall.
Shanling M0, firmware 2.1 notes
Download from Google drive
ZIP // File itself
Changes and fixes
1. While using M0 in Bluetooth receiver mode with iOS, volume setting on M0 is independent on iOS volume setting.
2. Fixed the problem of no sound coming out of M0, when being used in Bluetooth receiver mode with particular smartphones.
3. Optimization of system to prevent crashes.
4. Fixed other small problems.
How to update:
1. Make sure that M0 is fully charged.
2. Unzip the file and copy “update.bin” file into root folder of micro SD card.
Note: If your M0 is on firmware 1.0 or 1.5, card must be formatted to FAT32. For update from firmware 2.0, you can use all cards.
3. Choose “System Update” in system settings and wait until system restarts.
4. Check in settings “About M0” to be sure new firmware was installed.
Jul 3, 2018 at 4:38 AM Post #1,689 of 6,418
Ive
Yeah I would like to check the Comet out, but I’m afraid they’re going to hurt my ears since they have a wide nozzle and are made of metal. So I’d like to buy them from a place with an easy return policy- like amazon.
And the Sony dongle is pretty expensive on its own. You’re talking over 400 dollars for both comet and Sony receiver. I was thinking there might be some decent Bluetooth iems that had the Bluetooth built in.
Not a huge deal, I can always go wired and I have Bluetooth full size cans, but of course I’m not going to use them mowing the lawn :wink:.
I've got some comets arriving in a couple of days, a lot of great reviews so I was intrigued to try them. For what its worth I'll post up how they sound with the M0, at least compared to the Oriveti New Primacys.
I have the same issue with fit and always need to use the smallest of ear tips, so will be interesting to see how they work as they're a very different fit to most iems as these just poke out :wink:
Jul 3, 2018 at 5:20 AM Post #1,690 of 6,418
When was the last time you heard of a 2 pin connector failing? I understand the big majority of manufacturers use mmcx, but doesn't mean it's better. I find the modified T2 connection from ue to be a better solution.
Jul 3, 2018 at 6:15 AM Post #1,691 of 6,418
ZIP // File itself
Changes and fixes
How to update:
Any news on the possible introduction of a triple-click for the wheel button ?
Jul 3, 2018 at 6:38 AM Post #1,693 of 6,418
Cant recommend this setup enough..Shanling MO connected per Bluetooth to my true wireless Jabra Elite 65ts..Amazing crisp, full sound and a rig so tiny it fits in one hand when carrying it with you in the summer!
Jul 3, 2018 at 6:44 AM Post #1,694 of 6,418
ZIP // File itself
Changes and fixes
How to update:
Thanks Shanling thats great news. Will test it out.
Jul 3, 2018 at 7:47 AM Post #1,695 of 6,418
