999 bugs in the codeI take it you're not a programmer
999 bugs
You take one out, patch it around
1846 bugs in the code
Why do you think so ?I take it you're not a programmer
[PLAYER]
VOLUME=50
[PLAYSET]
JUMPFOLDER=1
BOOTVOLFLAG=0
BOOTVOL=20
MAXVOL=100
BALANCE=10
EQFLAG=0
EQTYPE=0
GAPLESS=0
MEMORYPLAY=1
FILTERMODE=3
[SYSSET]
LIGHTLEVEL=50
LIGHTTIME=2
BTCODING=2
THEME=5
DEEPSLEEP=1
SAVETIME=0
USBVOLMODE=1
You need an OTG adaptor.My Shanling M0 works great as a USB DAC when connected to my Mac.
But when connected to my android phone (LG V30) with a usb c - usb c cable, the M0 doesn't go into DAC mode and the phone doesn't switch its audio to the M0.
Any ideas?
I've never yet found a USB-C OTG adapter that works from my M0 to my LG V30 or V40. I'd be interested to know if anybody else has had any luck with this. M0->Hugo 2 works great. Mac or PC->M0 works great. But M0->USB-C Android phone = not working for meYou need an OTG adaptor.
I tried an OTG adapter. I can connect the LG V30 to a radsone ES100 successfully with that cable, but not the M0.You need an OTG adaptor.
You are fundamentally wrong, I'm just a programmer.
I do not speak English - I described it as I could.
Did the integer bother you ?? And float (32 bit) would not bother you in the description ??
I'm not sure that's correct. Usb-c to Usb-c is all you need. I think it's more a USB setting on his LG. I use basic Usb-c cables to my Samsung and transfer files all the time. This was discussed many many pages ago.You need an OTG adaptor.
I never tried. But I can in a few. My M0 had been sitting in a waterproof case for a long while. And touch controls on BT buds suck for swimming by the way.Are you also able to successfully use your M0 as an external DAC to your Samsung phone?
Please answer those questions for Shanling M0:
1. Will a full-fledged parametric equalizer be implemented in M0 (as in m5s)?
2. Will MTouch OS 2 be on m0 (as already done with m5s and m2x)?
3. Is it possible to make at least manually created presets for equalizer?
A text editor on a PC, with a file on a microsd?
File Name: CustomEQ.ini
Suppose in the format:
Where is the variables% f is an integer from -12 to 12. In decibels.
Better if it supports decimal values.
Programmers work coding for a maximum of one hour.
At the moment, Shanling M0 is probably the only music player in which the equalizer functions are completely absent.
The available option with preset settings is not acceptable for the music player.
The absence of a custom equalizer in Shanling M0 is currently the main drawback in sound.
And the lack of programs for IOS and Android is the main disadvantage for convenience.
The vast majority of competitors have this functionality for a long time!
Ears, hearing and headphones are different for all people!
Does Shanling, when developing M0 software, stubbornly considers them all equal and unworthy equalizer?
Any ideas?
Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Thanks Frankie, I'll look into the settings. TBH, it's not a big deal, since my phone has the exact same DAC and amp as the M0. Just a curiosity for me...I can only say, look into settings of your phone.
We tested M0 with bunch of different Chinese phones running Android 8 and it worked on most of them without any problem. Unfortunately world of Android is so vast and random, we can't do much more.
One other thing to try: Get cheap USB-C OTG adapter and try standard USB-C cable that comes with M0.
We are working on new EQ system for MTouch 2.0, when we are satisfied with it, it will be released for M5s/M2x. If we get good feedback, it will be ported to M0.
We are looking into importing some of elements of MTouch 2.0 into M0.
No plans to add such system, where users would need to set some files on their computer.
But we are open to any activity by users of Shanling players. Community has access to our firmware files and our system is build under GPL, so you can reach out to us to acquire needed files.
