Originally Posted by Swiss-BJ
Hello with all,
I am a new member registered on this Forum
I would like to pose to some questions with you specialists , I am reflecting for a purchase either for "Sensaphonics ProPhonic Soft 2X", or "Ultimate Ears EU-10 Pro"
My question is mainly about the "Sensa" and I wonder which is the solidity of these long-term ear-phones (I specify that I am very careful).
I speak about the ear-phone itself inside as well as fixing of the cable.
A negative point (for me) it is that one cannot have the cable of the "Sensa" in black but only of only one color
It is really a question which worries me to be able to decide to me, especially that the "Sensa" seems to me really softer and pleasant in the ears for long use compared to the "EU-10"
A point interesting for the "EU-10" it is the fact that the cable is replaceable if it is damaged. What think about it?
Please help-me
Best regards,
Stephane
Yes the sensas cable only comes in clear but the ear pieces come in many colors. It's probably is best to get clear to match. I have all black ue10 but I actually prefer the clear sensas because they don't stand out as much. They also dissappear in your ears.
The ue10 replaceable cable is an advantage but how often are you going to replace the cable. I have Grado RS-1 that don't have replaceable cable and it doesn't make a difference. I know in a portable setting the cable can get caught but the sensas cable is very strong and durable. The ue10 does come in a longer length which is nice.
The sensas are much softer and isolate better. They are much more comfortable when lying down. In normal use there is not that much difference but a small advantage going to the sensas. The advantage goes to the ue10 for easier insertion and removel.
As far a sound quality, if you have a way of giving the sensas a slight treble boost, I think they sound better than the ue10's on a flat eq. The sensas have better rhythm, bass punch, lowend texture, warmth, balance, and just musical enjoyment. The ue10 has deeper bass and higher highs with a little more detail but doesn't sound as balanced in the mids. The bass also has a weird puffiness to it. Like I can feel the pressure of the bass but not hear the detail. I found myself now disliking the sound more and more the longer I've been using the sensas. It's kinda of stange since I used love the sound and preferred it the sensas at first. As I said, the sensas just need a slight treble boost to sound their best.
I think the sensas are very durable. The actually bounce when you drop them on a table. You just need to clean out the bores daily or evey other day and put them in a case when not in use. I use Cable Turtle:
http://www.organize-everything.com/catusm.html but you can find other good cases. The pouch the comes with them is really too small and the waterproof case is more for long term storage. When I need to quickly put them away, I pop the earpiece in the cable turtle and let the cords hang out.
