rkw
But, as is aid, HD6XX cable is thinner than HD650 cable.
I'd guess that it is thinner for more flexibility, since that cable was originally meant to be used with the portable Apogee Groove.
Lol, double blind. Ok will do that after full burn in of HD6XX. Right now it's only 30/40 hours burn in ...
I'm not being cynical, really curious. I heard the difference once on an HD800 setup. It wasn't double blind but the difference was discernible and I had no idea what was what so it might as well been double blind. I'd like to repeat the experience but that was quite a setup from the power source up. Necessary, I don't know, I didn't get to hear the improvement of each component added. If the HD650 cables are noticeably thinner, that's a little concerning.
I said Hd6XX cable is thinner not vice versa.
For the length a headphone wire is, and the amount of power going through the wire, headphone cable in almost every headphone I've ever used is COMPLETE overkill. Frankly you just don't need a thick gauge of wire for that use. I assume it's thickness is more for durability than signal transfer.
I would almost bet that Sennheiser has a standard gauge wire that must be used. Even if the cable is thinner, that does not mean the copper is thinner, only a thinner casing of plastic.
Silver versus copper is a different subject, and I've never cared to look into the qualities of each to see if there could be a difference. If there is, why does silver ALWAYS sound better?
I have no desire to spend the amount of money required to upgrade my cables. I'd much rather spend that money on things that actually do make a difference, like a better DAC or headphone.
For power handling, yes, mostly overkill (<1W). But for "perfect" analog signal transferring, it's another story.
I would love for you to explain, with science please
A simple example is different resistance of cable.
Then the cable is too thin. A proper cable will have a resistance that has no effect on sound. The only example I can think of with a shipped headphone having a blatant resistance problem was the X1. Having said that, it could have been intentional by the designer.
What is your source? You probably need a decent amp. They will be a million times better than your other cans, you just need to feed them. It is worth the extra money.
Thank you, I'll try to find a better source for them
