Merrick,
Thanks for your reply on using the HD6XX w/a Jotunheim. Could you clarify how I would actually run these components from my PC? I am guessing, PC -> USB cable -> Mimby -> RCA out to SE IN -> Jotunheim -> Modded stock cable to XLRs balanced PRE out -> HD650 ??
Sorry if that does not make sense, not sure here.
thanks.
That looks right except it would be modded stock cable to single 4-pin XLR and it would plug into the balanced headphone out on the Joti's front, not the balanced pre outs on the Joti's back. Those are dual 3-pin XLR and aren't for headphone use.
Should I sell my hd600 and get the hd650.
Do you like brighter or darker cans? What are you pairing them with? The 650 is darker than the 600, and it synergizes well with different components.
