Alright. Here are my initial impressions with the following setup:
- Schiit Modi Multibit DAC
- Schiit Jotunheim amp.
- Single ended (I haven't modded a cable for balanced yet)
The Jotunheim is in low gain mode, with the volume knob at about 12:30.
I put them on a pink noise burn-in for 8 hours just for good measure. I'm not convinced burn-in is a huge deal, but I was busy with snow removal and not able to listen to them anyway.
[COLOR=1D2129]These headphones are only my second set of "good" headphones after the Beyerdynamic DT770 Pro's (250 ohm), so I will make my comments comparative rather than absolute, as I only have one frame of reference.[/COLOR][COLOR=1D2129]
[/COLOR][COLOR=1D2129]The Beyerdynamic DT770 Pro's which while marketed as a studio reference design, have a rather hi-fi oriented V shaped sound (in other words, lots of treble and lots of bass, and muted midrange) [/COLOR][COLOR=1D2129]Ironically enough, the HD6xx's are a lot more neutral, even though they are marketed as hi-fi listening headphones. I'm not used to this much mid-range. The Beyerdynamic's can often have a bit of a harshness to the treble if you are not used to them, there is none of that with the HD6xx's. I could go on listening to these forever without tiring out my ears. I was worried that maybe the bass would be weak, but that isn't the case at all. I find they provide a very nice and satisfying tight bass thump in the right tracks.[/COLOR][COLOR=1D2129]
[/COLOR][COLOR=1D2129]The intense highs in the Beyerdynamic's often give the illusion of extreme clarity. That is not present in the HD6xx's which means at first this can make them seem a little less crisp, but once you get used to them, the experience - I feel - is better. Particularly since I feel this makes the HD6xx's a little bit more forgiving to poor recordings. On the Beyerdynamic's I couldn't enjoy some tracks (Like Peter Gabriel's Solsbury Hill). The poor recording quality would bother me too much. With the HD650's tracks like these sound great.[/COLOR][COLOR=1D2129]
[/COLOR][COLOR=1D2129]The HD650's are open backed, so I was expecting them to have much more of a sound stage than the Beyerdynamics which are closed backed, but my take is that they are fairly close in that regard, with the HD650's coming out slightly ahead. I had read somewhere in the past that the Beyerdynamic DT770 Pro's have a lot of sound stage for a closed back set of headphones. I guess that is true. [/COLOR][COLOR=1D2129]
[/COLOR][COLOR=1D2129]Being open backed, they of course let in a lot more ambient sound than I am used to, but this is not bad when things are more quiet around the house. If anything, the fact that the sound is neutral and not harsh, allows me to turn up the volume more than I usually do, with them still being comfortable and drowning out some of that ambient noise anyway. The opposite is also true. More sound leaks out from the headphones than with the Beyerdynamics. So if you don't want to bother anyone, these are not the right headphones to listen to.[/COLOR][COLOR=1D2129]
[/COLOR][COLOR=1D2129]As far as physical comfort goes, the Beyerdynamics win by far, at least on my head. The HD650's have some adjustments, but no matter how I adjust them, they feel very tight. I do have a large head, and this might be why. Over time they might be uncomfortably tight. I might be able to bend them slightly to address this. The Beyers - on the other hand - are the most comfortable things I've ever put on my head.[/COLOR][COLOR=1D2129]
[/COLOR][COLOR=1D2129]It is clear to me these are better headphones than the DT770's, but that should be a surprise. The HD6xx's on massdrop sold for only $199 as part of the group buy promotion, but they originally had an MSRP of $650, though more typically sell for ~$350 these days, as they have been on the market for many years, and Sennheisers HD800 and HD800s have taken over as their new flagship headphones.[/COLOR][COLOR=1D2129]
[/COLOR][COLOR=1D2129]The DT770 Pro's I bought on sale for $139 7 years ago. So they are in different price classes.[/COLOR][COLOR=1D2129]
[/COLOR][COLOR=1D2129]I'll still have good use for the Beyerdynamic's though (especially when it is loud around me, or I need to be quiet) so I plan on keeping them around.[/COLOR][COLOR=1D2129]
[/COLOR][COLOR=1D2129]They are different headphones for different uses![/COLOR]
[COLOR=1D2129]One thing I am a little bit disappointed about is that the cambe they came with is a 3.5mm plug, with a TRS adapter, just like my DT770 Pro's. I don't understand why they do this on headphones with this high of an impedance. You're not going to want to plug them into your iPhone anyway. I would have preferred if they came with a TRS only cable, or better yet, a balanced 4-ping XLR cable and a 4 pin XLR to TRS adapter.[/COLOR]
It may seem like nitpicking by my DT770's adapter is a screw on type and looks rather premium. You wouldn't even know it was an adapter by just looking at it, when the adapter is on. The HD6xx's TRS adapter looks pretty cheap and obvious.
[COLOR=1D2129]I have bought an official Sennheiser replacement cable I was planning to lop off in order to convert the headphones to balanced. Interestingly enough, the replacement cable is TRS only. Because of this, I might just keep the replacement cable as my TRS cable, and lop off the included cable for balanced goodness, and get rid of that pesky 3.5mm plug.[/COLOR]
