Originally Posted by bigshot
The most important thing I've learned from acoustic reproduction is that there is a lot more to realistic sound than just frequency response, dynamic range and harmonic distortion. There are a bunch of other unmeasurable aspects of sound reproduction that are much more important... These fall under the category of psycho acoustics.
Your not being very clear, so I'll give you the benefit of the doubt. I'll assume you did not mean to imply that their are acoustic phenomena that can not be measured, but that you only meant that their is not an iron clad correlative system to interpret all measured data and the relative changes and how the brain specifically interprets such.
The average person when presented with high quality recorded sound will not detect any difference between the full range recording and the same recording with everything above 10 khz filtered out. That is a fact. |
Do you have the study reference available that demonstrates such? I am aware of the
[1]Plenge-Schone study demonstrating this is true for frequencies >15kHz(though this was done exclusively with audio professionals as subjects-not average off-the-street people), but have never seen such a study demonstrating >10kHz to be useless to 'quality'. It's important to define the specific importance of these frequencies because it is within the 20kHz range of human hearing.
Just about everyone prefers to listen to music with less than a 40 db dynamic range. |
Reference to the study establishing such? I know that 40dB certainly is
[2]not adequate for transparent reproduction, but I have not seen a study on 'preference', which is another issue entirely.
Audiophiles who cherish tube amps don't like them because they are "clean sound"... They like them because they like the harmonious sound of the *distortion* these amps create. |
Most tube amps do not produce audible levels of harmonic distortion. The most common type of tube amps that produces levels
[3]known to be within human noticable differences are some SET tube amplifiers which may produce THD into 3-5% range during normal operation.
If that's the case, why bother worrying about frequencies above 20 khz, dynamic ranges beyond 70 db and distortion levels below .1%? There are other ways to make music sound good that can make more of a difference than hair splitting like that. |
The 'modern' phonograph transfer to playback process produces levels of THD that are audible
[3]. I can only imagine what degree of harmonics are produced by the old phonograph technology to which you refer. I would find it interesting if you have such data available -- just for curiosity's sake.
I'm convinced that the key to good sound is balance... and balance in the midrange around the voice is most important of all. |
I'll agree.
-Chris
Footnotes
[1] Which Bandwidth Is Necessary for Optimal Sound Transmission?
G. PLENGE, H. JAKUBOWSKI, AND P. SCHONE
JAES, Volume 28 Number 3 pp. 114-119; March 1980
[2] Signal-to-Noise Ratio Requirement for Digital Transmission Systems
Spikofski, Gerhard
AES Preprint: 2196
[3] Just Detectable Distortion Levels
James Moire, F.I.E.E.
Wireless World, Feb. 1981, Pages 32-34 and 38
