Sennheiser MOMENTUM Review
Jan 7, 2015 at 7:21 PM Post #3,391 of 3,594
So, not only is there a Momentum M2, there is a Momentum wireless Bluetooth with ANC. Personally not interested as wire do not bother me. What does is a small piece of technology breaking that would render the phones useless, such as say a slimline hinge, battery, amp/volume control, bluetooth receiver etc. It is not a matter of if but when and that is $500 down the drain (after the 2 year warranty). So very glad that they have it an option.
Jan 25, 2015 at 3:54 PM Post #3,395 of 3,594
I asked this in a separate thread, but what are good complimentary headphones for the Momentum? I just got a pair of them last week and while I like them, the lack of sound stage and rolled off treble makes me want to get a complimentary open back pair of cans.
Jan 25, 2015 at 3:56 PM Post #3,396 of 3,594
Grado SR80, AKG 701.
Jan 25, 2015 at 3:57 PM Post #3,397 of 3,594
i love my 598 :D
Jan 25, 2015 at 4:11 PM Post #3,398 of 3,594
Beyerdynamic DT880
Jan 25, 2015 at 4:28 PM Post #3,399 of 3,594
  Beyerdynamic DT880
+1 on this however if you are using them for portable use, you may look like a Spaceman/robot wearing them out in public. I also would recommend the 32 Ohm version.
Jan 25, 2015 at 5:56 PM Post #3,400 of 3,594
Wow! Thanks for the recs! I think I should clear a few things up:
1: I had the Beyerdynamic DT990's Premium 32 ohm just before I got the Momentums. Due to circumstances (read: money), I couldn't have kept  the 990's and purchase the Momentums. I think the 990 would be the perfect compliment to the Momentums but I can't afford to get them in the near future. I doubt I'd be able to get the 880's or the K701 in the near future as well, unfortunately.
2: I'm not looking for another portable headphone. Just another complimentary headphone that covers what I feel like are the Momentums weak points.
3: My budget is probably around $150. Which isn't that high, but I think it'd be adequate to get me a solid pair of open back headphones. Even though I know I won't get anything that was as good as the 990's I had.
Does anyone have any experience with the Audio Technica ADxxx series of open back cans?
Jan 26, 2015 at 3:10 AM Post #3,401 of 3,594
Maybe AKG K240.
If you can get the treble down slightly through modding, I would also recommend the Presonus HD7... I found it slightly piercing even after modding, but I'm quite sensitive to treble.
Jan 26, 2015 at 12:23 PM Post #3,403 of 3,594
Maybe AKG K240.
HD7 looks exactly like Superlux hd681b. 681 is 1/2 the price.
http://www.amazon.com/Superlux-681-Dynamic-Semi-Open-Headphones/dp/B002GHIPYI
Jan 26, 2015 at 1:11 PM Post #3,404 of 3,594
Looks and sounds are two different things.
Since I've never heard any Superlux I can't recommend it.
Have you heard any of the Superlux models?
Jan 26, 2015 at 1:29 PM Post #3,405 of 3,594
true but I'd be willing to bet they come from the same factory.
