n00b2
- May 14, 2013
Ok thank you...
At the end...
Wired M2 are near the same M2 wireless and M2 wired are better than wireless M2 (passive mode), but the M2 wireless (active or passive mode) that are better than M1 wired version.
I think the best option for me is the M2 wired because I listen then 90% into my room.
Have I done a good recap?
Do you choose wired or wireless version for my need? (Consider also that wireless version is too expansive)
Thats not exactly what I said but you may well be right on that in the sense that if you try all of them that is the order you will end up. My order was slightly different to what you recapped. The first bit "Wired M2 are near the same M2 wireless" I don't know if that is true as I never tried M2 wired. I said it was better than M2 wireless passive but I don't know if it is as good as M2 wireless active. Maybe some other posters or previous posts in this thread can help you out there if you are unable to try it first?
From what you have said in that post though (assuming the M2 wired and M2 wireless active sound very close) I would say yes get the wired model but you probably should consider a few other things first. The basic question to ask is do you need the noise cancelling or bluetooth function? If you don't need those features when in your room and money is a concern then there it is probably best to get the wired model unless that remaining 10% of the time happens to somewhere when ANC or bluetooth would be extremely useful for example a plane.
That said, if you can afford it I would still get the wireless version. The battery lasts ages and if you are sitting at a computer desk you can connect it via USB which I believe will charge the headphones while you are using it (can't say for sure but my Def Tech Symphony 1 does and I believe I read before that the M2 wireless does too). The sound over USB is by far the best out of all the modes on the M2 wireless (I strongly suspect it would be better than the M2 wired that way). It charges pretty quick too so unless you never usi it sitting at a computer desk you should never run out of battery.
