Sennheiser IE800 IEM's
Jul 26, 2017 at 2:38 AM Post #7,021 of 7,998
Hello guys,
I would like to read advices about how to drive Sennheiser IE 800. My question is: from a good top-end smartphone o from a dedicated DAP? Do they need a heavy amplification?
Thank you!
kalo86
Jul 26, 2017 at 9:15 AM Post #7,022 of 7,998
Hello guys,
Thank you!
kalo86
You won’t have any problem using the ie800 with a phone, but if you want to squeeze the best out of these iem, a dap is recommended.
Jul 26, 2017 at 9:19 AM Post #7,023 of 7,998
Thank you for the answer. Maybe the best solution could be a dedicated dac+amp (for example Xduoo XD-05) with the digital input from the smartphone with OTG cable. I hope that Amazon Italy will propose a new offer on their website for the Sennheiser IE800... Regards!
Jul 27, 2017 at 10:32 PM Post #7,024 of 7,998
Hello guys,
Thank you!
kalo86
Dac is more important than an amp with IE800
Try to acquire a great quality dac with a decent headphone out, i would avoid anything bright unless you dont mind it.
Jul 28, 2017 at 1:02 PM Post #7,026 of 7,998
Jul 28, 2017 at 1:43 PM Post #7,028 of 7,998
Jul 28, 2017 at 2:06 PM Post #7,031 of 7,998
Hello guys,
Thank you!
kalo86
Ie800 doesnt need a strong amp, but a dac will give you more resolution no matter what device you listen with. Bad input, bad output regardless of gear. To me however, there isnt a big difference between my lg v20 and hugo for the ie800s. Summitfi iems like my laylas do a much better job of revealing good dacs. If you have a dap already that should be just fine for ie800s.
Jul 28, 2017 at 4:14 PM Post #7,032 of 7,998
O
22 sold, imagine how likely they are to be authentic...
I'd say that with ie800 it is best to get them from authorised sellers only
I bought mine from AVstore Romania and couldn't have been happier with the services provided, maybe this helps you if you are from Europe. Although I am not affiliated with them, I am glad to see that they generally offer really good prices for all their items.
Jul 29, 2017 at 7:23 AM Post #7,034 of 7,998
Thank you for the advice. In my opinion, if IE800 requires an amp, what does Sennheiser HD600 require? A nuclear source? I have several 16 Ohm iem's and they sound pretty good from an XDuoo X3 and/or OnePlus 3T smartphone. I don't notice a huge difference between a dedicated DAP and smartphone (until the iem impedance is low, about 16 Ohm).
Regards,
kalo86
Jul 29, 2017 at 11:11 AM Post #7,035 of 7,998
Regards,
kalo86
Ie800 is probably the IEM that I'd hardest to drive from all my collection though, so please keep this in mind.
I still think that volume wise it can be driven from almost any smartphone, but for the best quality / sonic results, you might want to use a higher quality source.
