Dobrescu George
Reviewer: AudiophileHeaven
guys i am not here to derail the amazing ie800, but anyone who cares about a great addition to the ie800 add to your list to look at ibasso it03, this cheap 250 usd iem totally surprised me and really showed me that sometimes in life we get surprised by cheap products
250 USD is not cheap at all.
Very very basic question:
With my IE800 the Sennheiser supplied adapter cable (from the IE800's 2.5mm plug to the standard 3.5mm plug) ist broken, and because I anyway wanted a shorter cable, I ordered a standard aftermarket 20cm cable (with a 2.5mm female connector and a 3.5mm male plug). Much to my dismay the IE800 plug does not hold within the standard (?) female connector of the delivered cable. Sound is transferred, but mechanically there is no "plugging" resistance and mechanical withhold (if I can express that in an understandable way).
a) is the IE800's 2.5mm plug a standard one?
b) if no, can somebody kindly point to a fitting aftermarktet adapter cable in the range of 15..30cm length?
Thanks for a knowledge transfer...
It should be a standard 2.5mm connector, and should work with other connectors, tho there is not a single best one expressed in this thread so far or at least since I've been a part of it.
A longer cable would be sweet
