Sennheiser IE800 IEM's
Dec 14, 2016 at 4:38 PM Post #6,002 of 7,990
  Careful...TDK ie800...confusing right!
totally because i own the comply 400 and they slide off and get stuck in my ears easier than any other tip
so everyone should be aware and thanks for calrifying that
Dec 14, 2016 at 4:39 PM Post #6,003 of 7,990
Sorry about that.  If you do a search for comply in this thread there's talk about them making one but it doesn't appear to have happened yet.
Dec 14, 2016 at 4:41 PM Post #6,005 of 7,990
http://www.complyfoam.com/products/sen-isolation/
These are the Comply tips I use with my IE800s! It doesn't say on the page that they're made for the IE800 but they fit them that's for sure. It's a really snug fit so no chance they're gonna fall off.
Dec 14, 2016 at 4:44 PM Post #6,006 of 7,990
Good to know...maybe they're the same circumference as the 500s?
Dec 14, 2016 at 4:52 PM Post #6,008 of 7,990
One could theoretically remove the center tube from a pair of ie800 tips, Chinese ones may come in handy for this, then get a Comply or similar memory foam tip that fits the tube from the Senns tip…believe I read this somewhere else.
Dec 14, 2016 at 4:54 PM Post #6,010 of 7,990
Dec 14, 2016 at 4:54 PM Post #6,011 of 7,990
can u link me to this chinese thing i can buy and do the mod
Dec 14, 2016 at 4:55 PM Post #6,012 of 7,990
  .…believe I read this somewhere else.
OK found it...
I've seen the talk about comply 500 fitting the iE800, if anyone is interested to know I made a slight mode using the smallest earbud "as it's too small for me to use" I turned it inside out, cut the bud off leaving only the cylinder post that attaches to the monitor. If you put the post back into the body then push the T500 onto the post part or most of the way. Pull off, lay on flat surface press the comply bud the rest of the way on, as it fits snug then reattach, and you have a great bud now that we wish could've been included from the start ☺️
Dec 14, 2016 at 4:57 PM Post #6,013 of 7,990
a few pages back...although I've heard mixed reviews on these...
  Again Aliexpress....
https://www.aliexpress.com/item/Top-Quality-In-Ear-Headphone-Headset-Replacement-EarBud-Ear-Buds-Tips-S-SM-M-L-4/32464706018.html?spm=2114.40010508.4.78.JQs0ka
Almost the same quality but I'm still not sure if one gets the medium round, my size, with this set?
Dec 14, 2016 at 5:03 PM Post #6,014 of 7,990
  OK found it...
and with this mod u can even use maybe other silicon tips
that mod will open many experimental doors for me to play with wow never thought of doing this mod
Dec 14, 2016 at 5:52 PM Post #6,015 of 7,990
Keep in mind the Senn proprietary (barrel) attachment is half the length of other tip cylinders and the screened end is almost flush to the phones opening.....which is probably integral to the over all performance as the sound is less influenced by the barrel as it leaves the driver.
Also explains why it has an actual attachment as it is with some full size headphones.
