pietcux
Guys try the sppin fit on this, they are superb, improve isolation and reduces microphonics. The also stay on with no problem. What a nice accidental discovery.
Could you supply a link on those, please?
for me large is needed else the fit will be too deep.
Something tells me something isn't right here, there is lots of cable noise (especially from the 2.5mm connector if that moves around) and, from an earlier post, there is definite wind noise also, very easy to pick up...
Ignoring the model I'm about to mention here, this is not a 'this IEM is better' post, yet when I moved from the IE800 to SE846, the reduction of cable noise and increase in occlusion were, at the time - worth the entry fee all on their own.
@DrGonzo
I just got rid of the IE800s after having them for about a week. I liked the overall sound signature and size/fit but found the cable noise extremely distracting. Even if I were laying down and sitting still, I could hear cable noise caused by the movement of my chest while breathing. Adding a clip helped a bit, but not nearly enough. I tried the over the ear suggestion, but it was tight around my neck and added to the problem of the cable already being too short. Isolation is not good either relative to other IEMs. Based on what you wrote, I would look elsewhere.
Sorry, I meant the size of the hole that fits onto the IE800. I had heard that the original models didn't fit the IE800, but then they made a larger or a smaller version that could be used with the IE800. I don't want to buy the wrong kind and not be able to use them at all.
Hi guys!
One question: how does the IE800 sound compared to the Audeze EL-8? I would drive it with my Sony NWZ-F886 DAP.
Wonder how you're achieving this, my experience has been quite different: average isolation (clearly less than Shure / Westone / Ety) and noticeable wind noise from the back vent.
The better isolation can be achieved by deep insertion or by having a large body. IE800 doesn't have either of those, in fact quite the contrary. One can see George is quite enthusiastic about his new IE800, but these are not the end of all IEMs.
There will never be and end of IEMs. But there can be a step after which you do not feel the need to go anymore.
I do insert ie800 mid-deep, not shallow, maybe this has a word to say. I use oval large, to have a good soundstage, and for me the insertion is slow and sometimes hurts, so it might be a reason for which I get great isolation and sound, and no microphonics?
On the other hand, trying to get anything else after you have ie800, I can only see one trying to get more soundstage. rest is pretty much enough and very likely the end of it all. And I do doubt that there will be possible to put more soundstage in an IEM.
I do like ie800, and I am a hard to please man. I actually was not entirely happy with any headphone / IEM before Ie800, but I always accepted the deffects. Now, I do not feel that I need to accept any more deffects, as I see none.
I still use my full headphones sometimes, and there are days when I am not in the mood for it, so yes, I do think that there can be better, but no much better.... This being said, I can live happy with ie800, and stop searching for better IEMs. Now to focus on some headphones that I can like as much......
