They were stiff from the beginning,I havent noticed any change since I got them.
But dont you find it annoying having to look at them closely every time looking for the left or right one ?
Also is there any link to say the stiff cable is a warranty issue,so I can show the seller if I decide to return them..... thanks
[/quote
Left and Right.....the left has a dimple on the cable stress relief just run your finger over it and you'll feel it on the inside ....very easy way to tell left from right.....second just hold them up tips pointing away from you they should two out "meaning left will toe out to the left right will two out to the right away from you"
very easy to tell this way too
Oh I think you should return them if your cables are stiff because they have updated the cables since then if I'm not mistaken because as you said the other pair is not like this ....if you like it it's cool but don't bash them later if they stiffen up over time and you didn't return them because I believe they've worked on this issue.....if you wear over ear though the stiff cable is ok because they will slightly mold behind the ear "if you can most people can't or don't like" I wore them this way for a while but I actually prefer cable down as if you wear glasses or sunglasses as well it's just something you don't have to think about .....I never thought about this before because I always had over ear IEMs
