Hifiearspeakers
Yes. Again, well controlled. Bass is a tricky thing. Some like the excessive amounts in the Foster series, for someone who does like bass, it's too much for me. While some feel bass can't be full extended or higher in level than the mids, which to me can mean deficiency. This shows up in a lot of planars, Audeze in particular. The bass extends well, but is flat through the mids, which will
make it seem deficient. The Harman Curve is the inverse of Fletcher Munson (the curve showing the sensitivity of our ears). By increasing bass and sub bass to be higher than mids, the bass is going to sound more correct, since we hear mids better than bass. How much is the issue. What I heard in the HD820 was near perfection. Mids were not recessed, bass was there, extended & without overdoing it. I look at it not just as a part-time audiophile and fan of headphones and bass, but an engineer who wants to hear everything, and in proper amounts to make mix decisions.
I'm sure you can. I tend to listen without EQ on my home studio system or my phone. I want cans to be where I want them without apps and knob twiddling. I want to plug them in anywhere and the sound is similar. I'm familiar with what EQ does with phase, even digital EQ, and while Linear Phase EQ prevents that it introduces transient smearing pre-ringing. That explains my quest in seeking cans that are already there. I had given up on cans being close to this but have found pairs recently that surprise me how close they get. These seem to get all the way there to my ear.
They tried an adjustable closed and the result was a heavy headphone that just didn't sound very good to my ears. Beyerdynamic failed in this regard too. So much has to be done in building it, there's nearly no chance a slider on each cup can make those kinds of changes, and probably not even popping in and out different internals. That would be a Frankenstein of a project, and the attempts I've seen for that have fallen short in my opinion. The TH900 bass is too much for even my ears as a starting point, and would greatly reduce the accuracy that these hold a promise of bringing to engineers who have sworn off headphones for mixing, in making them usable in the studio. Again, we don't want hype, we just want full extension on both ends, with the curve that a ear naturally prefers. This reduces fatigue, and the closer a pro quality reference mix (Steely Dan for example) sounds to perfect on cans, the closer to perfect the cans are. If you hear a boomy bass on a song with a normal amount of pop / rock low end from the late 1970's, it's no go. If the full subby decay is gone upon close listening, it's too rolled off. It's an elusive target but worth it. They pretty much spared no cost to make this what it was. It's the first of a new class, there is no reason to think it won't trickle down to improve other beloved 500 and 600 series cans one day.
Awesome! Thank you! I don’t want crazy amounts of bass added. I just wanted to know that there was at least a little more than the 800S. To my ears, I find the 800S mid bass perfect. It just actually needs sub bass. If the 820 addressed that, then I’m very excited.
