ruinedx
- Sep 11, 2016
LP actually has very unique voicing, it sounds smooth like a typical tube amp but fast and clean like a typical solid state amp, which makes sense since it's a hybrid. Smoother than Schitt headphone amps for instance, but not necessarily super warm, kinda like warm-neutral. It sounds utterly amazing with hd820, even with stock tubes. It's a near perfect pairing. Note this is in combination with my Musical Fidelity MX-DAC, which has a little special sauce of its own. The three together have a special synergyYeah, good thought. I should probably at least give them a shot on the HeadAmp when I go inside tonight.
How do your 700s sound on LP? Any other amps you’d compare it to?
For the HD700 it also works but after hearing the near-perfect hd820 and going to the hd700, the hd700 sounds a bit "hollow" likely due to the large upper mid-range depression the hd700 has. However when listening to the hd700 on its own without reference, it sounds very good too. Its just when compared back to back with the hd820 it's clearly not as good
Should get the BEL tubes in a few days will be interested to see if it gets even better
