flailure
- Jan 31, 2014
I have run into a strange issue.
Listened to a ton of music, and two tracks both exhibited a problem that make me question if there is an issue with my specific headphone. Then again it may just be an odd resonance or something.
The introduction of both WHITE ZOMBIE's THUNDER KISS 65 and OZZY OZBOURNE'S CRAZY TRAIN (which both have distorted guitars) result in a couple of brief and SUBTLE high pitch but low volume buzzing/rattling instances in the right earcup . It is something you really have to listen for to notice . Has anyone experienced this? Could possibly be recording as well (or my hearing, I can hear higher frequency with my right ear than left) its hard to tell with the wide soundstage of this headphone but with these two songs I am hearing it. I've listened probably to over 100 songs of varying genres and haven't heard it anywhere else, even at high SPL.
I don't believe its a power issue as both of these passages just have electric guitar and I've played tons of much more power-demanding material with no issue.
I was going to listen to those songs, but can't seem to get the wifi to connect to my fiio, i know I have at least one of those in my cd collection, so I will test it out once I get going.
I have not noticed any rattling with mine, but I have found an odd distortion that seemed to be linked to extremely panned bass. Heard it on a few recordings, all of them older, wondering if this may be related.
Glad you like the headphones though, I also prefer them over the original hd800, although, it was a close call. I listen to a lot of orchestral music, and some of those old recordings just don't like bass. But, the majority of my collection does sound superior on the hd820, and i prefer the soundstage on the hd820 as well, or maybe I should say that the placement of the instruments sounds more natural to me on the hd820.
In regards to acoustic guitars, on most recordings you wouldn't notice much but a slight thinning on certain sections, but certain low notes can be affected by that dip, to the point where both sound subdued and instrument placement is effected. Its not subtle when it happens. It is not as bad as I first thought it was though, been operating without an equalizer for a few weeks now and most recordings are not affected. A plus 5 db boost on an eq at about 270-300hz pretty much eliminates it, sounds more natural.
