- Jun 20, 2010
Do you mean to say that if you remove them you can't reattach them easily?
I would hope there's a path back to putting them back on if A/B'ing the sound shows they don't affect the sound.
Unless someone with the HD820's can try the A/B test, and put them back on successfully, I'll have to try for myself someday...
For now my M15 + SendyAudio Aiva's are doing great, but the Aiva's will likely get lonely... eventually, but I did buy an extra pair of earpads.
Any suggestions on other alternatives to the HD820's? $2400 is a big lump sum, even a used pair of HD820's at $1800 is more than 3x the Aiva's cost.
Any other closed back's I should consider? Right now I've only the Sennheiser 598cs, Audio-Technica ATH-ANC900BT, and a bunch of broken Sony BT headphones - no more of those for me, and a pair of Beats Studio 3's, a bunch of IEM's (balanced mostly).
I need a companion closed back of the same sound class as the Aiva's - or better - for the M15 4.4mm High Current mode to feed.
ZMF Eikon and Sony MDR-Z1R.
