well I dont know the difference but the HD820 with micro dsd sound like total dog poo
LoL! That's clear for me, thanks!
Is there a Sennheiser rep on these forums?
I’d like to officially log a formal concern with the fit issue. Knowing how well these sound when the fit is right and knowing that you have to struggle with fit 98% of the time, it makes the price very hard to swallow.
I feel like the fact that they recycled the design of the 800 ended up hurting these headphones because there were scenarios that they didn’t account for in terms of fit. I’ve gone through multiple closed backs sets (Z1R, z7, Denon 7200, cheap Bluetooth ones, etc...), the one thing that’s common between the good ones was some type of material on the pads that help with sealing.
In the case of the HD820, it feels that Sennheiser couldn’t figure out how to make this seal. I could think of a couple of solutions like spring loading the ear cup mounts, using a different shape headband, have two attach point for the cups vs just one etc...
I can’t help but thing this is a design defect with the headband assembly, it works for the lighter cups of the 800 and 800S but has not been adapted for the 820.
I seriously hope that Sennheiser reads these forums and is actively doing something to fix this - I’m seriously considering getting rid of these ... I can’t even imagine the number of people that skipped these because they sounded like half of what they should really be because of bad fit...
This is one case where having multiple cans in rotation isn’t so good cause you just can’t figure this out quickly enough between rotating other cans and other gear (amp, dac, dap, etc....) ...
On a lighter note, lesson learned is next time I buy something, it’ll be in priority rotation for the duration of the return period ... having gone through the entire 600, 650, 700, 800S, I figured Sennheiser couldn’t screw this up but should have known, after all they made the HD700 ... sorry, couldn’t resist ;p
/A concerned owner...
maybe only a select few, I never had any problem with fitment
Definitely possible that it's my head shape\size - I did go through this thread searching for fit issues, found some cases similar to mine ...
Are you able to get to a point where slightly pressing against the ear cups no longer changes the sound (most audible in the bass)?
On my other closed backs that seal properly, once they are on, I can do slight presses on the ear cups and the sound stays the same. I have never been able to get to that point with the HD820 unless I keep my hands permanently on the cups.
Cheers,
do you have a bony jaw line?
my face is round so I have no problem, bass slam pretty hard, the back of my throat feels it every time, the attack is not as fast as Planar magnetic but pretty damn good.
Have you consider to change the ear cups/pads?
Round shaved head and bony jaw line, glasses and tall ears so I could definitely be considered edge case . I absolutely love the ear cups of the HD800, one of the few where my ears don’t feel too claustrophobic so the 820 was a natural option to try for me in my search for a closed back.
I feel like I’m getting close but just wish it was as easy a fit as other cans.
Not on the 820 but I did try Dekoni full leather pads on the 800S before I got the 820. I thought it made the 800S sound like a banshee because some of the sound was now getting trapped. It also created a weird ear pressure situation so I now stay away from pas rolling the hd8x0 series but I might try for the 820 if I can find something that fits\seals like a Sony closedback while preserving the sound signature.
Just thought I'd add a few comments on some recent purchases used with the 820. Bought a used Hugo 2 and was worried they might be too detailed, especially since my main amps have been tubes (Woo WA7 & Loxjie P20). Well they bring out details I've not heard before and I don't find the combo fatiguing at all. Noticed some birds tweeting in a Jack Johnson song I've heard hundreds of times (without hearing birds) for example. Excuse my poor use of terminology, but with some songs the bass is such that at times it's like little puffs of air hitting my ears, which was surprising and wonderful. Of my limited collection, the 820s seem to reach a whole new level which my other phones don't quite as much with the Hugo 2.
On the flip side, got some Dekoni velour pads via Massdrop (for Focal Elex too). While comfortable, the pads ruin both for me, but especially the 820s. They seem like a mess with these pads compared to stock. Was hoping that by being thicker they would improve the fit (and bass) on my smallish head, but they're just blech. No problems getting them to fit at least.
Probably my 48 year old ears, but I hear no difference in any of the filter or crossfeed options. So I leave filter at 1 and crossfeed off. Haven't played with other phones with the Hugo much yet.Chord Hugo 2 have the filter setting, did you use it?
I heard the original chord is more neutral, I found it to be good listening.
