Whazzzup
In a few weeks from dhc? Weeks meaning months.
In a few weeks from dhc? Weeks meaning months.![]()
I did order it a while back. But yes it feels like a lifetime already. Can't wait on it. Decided to order the USB-DHC cables beginning of september as well. Just to complete the chain.
I had pretty quick turnaround on my DHC orders in July and June. August is big vacation taking month.
Are the frequency response charts being put somewhere different, now? Or, not available? Or, no interest?
is it sold. I don't see the listing.A company on eBay is selling the HD 800 S for $1150. Looks reputable. Might give it a shot :/
5).Some people said that after adding high quality USB cables to connect MOJO to PC (or i devises with Apple CCK) can get improved sound quality. Is that really true? What is the technical clarification for that?
YES!!..It is true. I also feel some difference (improvement in sound quality) when I replace default USB cable with Moon audio Blue dragon USB cable.
There's a common misconception that DACs and digital cables have an easy job- all they have to do is tell if a signal is a one or a zero, right? It's not that quite that simple. In wide-bandwidth data applications, the ones and zeroes have to be bundled up into packets, and these packets are passed at blindingly high frequencies through send/receive chipsets and across cabling. Every small impedance mismatch, and every bit of power supply noise,EMI, RF NOISE that travels along with the data… in our case, music, creates errors that can cause audible problems.
On the other hand I send email to CHORD MOJO technical support and ask them when sending data to MOJO via USB whether it use error correction or retransmission. And from email they confirm me that CHORD MOJO didn’t use error correction or retransmission when connect via USB.
So now I believe now you can clearly understand the reason for using high quality USB cables.
By the way ROB WATTS (the designer of MOJO) also mention that it better to use Ferrite chork for USB cable to eliminate RF noise come from host device.
Hugo TT versus mojo a complete waist of money? Well thx for your opinion but you lost me there. Completly lost on so many parameters. Mojo isn't great match for hd800S well Hugo isn't that good a match compared to TT. Granted I will also post impressions with balanced and SE high end amp with very high quality interconnects through high quality cables to hd800S in a few weeks via TT and its balanced xlr out versus RCA se out.
Good to hear you like your new amp
Congratulations with your new piece! Could you define please what difference you hear between the stock and better USB-cable?
Dear Friend,
first Thank you..
In here what I want to emphasize is ,if someone already have chord mojo and HD800S, it is not worth(money wise) to buy HUGO TT(4795USD) and instead far better to buy HDVA600(1600USD) and can use MOJO+HDVA600+HD800S.And this combination will provide far better sound with less money.
