skhan007
This is the way.EQ. It's free & very effective.
Agreed, they are okay in with stock tuning, but with EQ the HD800S’s sound so much better.This is the way.
That is so much an individual term. Some folks like extended bass, some don't, some prefer more treble, some mids, etc., etc. What's better, then?so much better.
Outside of the OEM pads not sure.Anyone have pad recommendations if I find the sibilance to be a little too hot at times?
Use PEQ to your own preference, simple as that.That is so much an individual term. Some folks like extended bass, some don't, some prefer more treble, some mids, etc., etc. What's better, then?
Cheers!
I should’ve added “so much better to me”. Music and how we hear it is personal. The choice of headphones and associated gear is all about individual preferences.That is so much an individual term. Some folks like extended bass, some don't, some prefer more treble, some mids, etc., etc. What's better, then?
Cheers!
For me the peak is indeed very present. I find that pairing with a tube amp somehow bends the tuning in such a way that the 800S sans EQ is all good. However, today I paired the 800S with my SS amp and forgot to apply EQ in Roon. The sound was great BUT after an hour I started to get listening fatigue. After a listening break, EQ was re-applied and all was well.The 6khz peak is still fairly present in the stock form. I like TP over EQ (I use DMG equilibrium) personally but YMMV. A dac that’s a bit laid back and does not tend to point a spotlight on everything in the music can also help.
Yep...6K or any any high frequency tone that is highlighted could be rather annoying for any sustained period.The 6khz peak is still fairly present in the stock form.
https://ca.sennheiser-hearing.com/c...-accessories/earpads+compatible-with-hd-800-sreplacement hd800S pads as is in Canada?
If you can try for an audition, originally when they first came out I was put off and called them "wonky" but now that all the initial negativity has faded I unexpectedly was able to give them another try but next to some competition.I’m seriously thinking of “upgrading” to the HD-820, mostly because of its closed back design.
...total reversal.got to do direct comparisons of the HD820 with some other closed backs.
I was able to play a wide selection from Tidal Hi-Fi, jazz, Dave Holland acoustic bass, classical, Stravinsky "Rite of Spring, some vocal work, percussion pieces and then some Kraftwerk.
First up were the Focal Stellia, which I'd not like at all, at least not for the asking price, nothing really special about them, think I preferred my Elegia. Second up were the Meze Liric which were quite sibilant, something odd about them not sure what was going on but it did not fair well.
The more affordable Dan Clarke Aeon sounded fine and reminded me of the HD600 series but the HD820 overall where just a lot more entertaining, the audio illusion is more immersive, bass was more than adequate, especially if one is fine with HD800S and the treble was IMHO the best of the bunch.
And now they're my go to, go figure.I would have bought a new pair right there and then If not for some up and coming dental crowns. : (
And as we all know being on Head-fi... resistance is futile![]()
Here you go. : )....usually a 10% code if accepting their news letter or just leave something in your cart and they'll send yo a reminder with an incentive.![]()
