Okay so let me ask a question, well-worn, if you will all kindly oblige…
What are your recommendations for OTL / SET tube amps for the HD800S?
WA2Okay so let me ask a question, well-worn, if you will all kindly oblige…
Gen 2 WA7/WA7tp with Mullard cv4003/EH gold pins is clean on a stock Harman/oratory1990 curve (not the one with a 10db Ls). Even cleaner fed by an ADI-2pro.Okay so let me ask a question, well-worn, if you will all kindly oblige…
The THX 789 -> HD800S is really bright with what I would call under-emphasised bass. I'm not a huge basshead (though I do enjoy my Focal Clear Pro and Audeze LCD-X 2021) but the 789 and HD800S combo sounds bright and not neutral.
I am contemplating a Soloist 3XP amp upgrade, those have swappable opamps to something with warmer tonality with no real worry of rarity.
Or the Violectric 281, would be amazing with the HD800S.
No DAC, Amp, whatever combo will eliminate 5dB peaks. Even sounded components change FR by < 0.5dB. The HD800/S just is a bright headphone. You can of course try "fixing" it by bloating midrange and upper bass, but you don't need a HD800 then in the first place. I've been using the HD800/S for 5 yrs+ now with all the components in my signature and the only way to handle brightness is either EQ or getting used to it. The latter doesn't really work for HD800 OG, at least for me.
Hey Sajid, how are you doing?Okay so let me ask a question, well-worn, if you will all kindly oblige…
Hey man, thanks for your response. Am quite interested in the Euforia.Hey Sajid, how are you doing?
I recently got a HD800s. I am using Feliks Audio Esspressivo MK2 amp with it. TBH, this pair sounds amazing. Feliks is not producing Esspressivo anymore. However, there are a lot better amps than Esspressivo which Feliks makes - Elise, Euphoria etc which people say pair great with the HD800s.
However, my dac is a pretty basic one - Soncoz la-qxd1. It's not bad but the other day I tried Astell&Kern SP2000s dap in the chain and it sounded really better - smoother, more controlled bass, a lot more detailed. I am looking to get a decent dac. If you have something in mind, let me know.
Thanks
@UntilThen ~ my big man .. i HEARD you !!!..Where do I begin?
My journey with tube amps.
Darkvoice 336se
Feliks Audio Elise
Feliks Audio Euforia
Primaluna Dialogue Premium HP
La Figaro 339i
Woo Audio Wa22
Schiit Mjolnir 2
Woo Audio Wa5le
Glenn OTL amp 6 x 6bx7gt with @paramesh now.
ALO Audio Studio Six
Elekit TU-8200
McChanson Destiny 300b amp
Ultrasonic Studio Oblivion
Ultrasonic Studio Odyssey - this is where I stop. I've found what I'm looking for.
http://ultrasonicstudios.org/odyssey/
@Sajid Amit .. knowing your SQ preferences .euphoria might not be up your alley !.Hey man, thanks for your response. Am quite interested in the Euforia.
For a DAC, check out the Holo DACs? The Spring is pretty good, esp L2 and above.
I wonder how much my Stellia’s bass would change due to the high impedance output of the Euforia…
@Sajid Amit .. there u go !!I know what will suit him. It's Odyssey with Telefunken EL11 and EL12 spez tubes with Sowter output transformers.
@UntilThen give the WA22 ... just cos i have all the best possible tubes for it !..Where do I begin?
Darkvoice 336se
Feliks Audio Elise
La Figaro 339i
Woo Audio Wa22
Schiit Mjolnir 2
Woo Audio Wa5le
Elekit TU-8200
