Hi all, anyone have any guide/guidance on how to get started doing some basic EQ for the HD800s?
Running from PC
Sure! look up peace apo, that is a system wide eq software that is free and is seems to be the most recommended/best in terms of software that is system wide and has the most customization that i can tell and it has other features like cross feed settings and such
and for hardware options there is the monoprice thx 788 amp/dac unit which has a low and high shelf function and 5 parametric eq settings, there is also the rme adi amp/dac unit which makes the eq functions more robust then the monoprice but the rme is double the price or more if i recall so i went with the monoprice and that is what i use now instead of any software since i needed not just pc system wide eq but eq that works with anything i connect to the unit like my ps4 and switch consoles
the only limit that the monoprice has it that it can not decrease or increase more the 6 db while the rme can go to 12 db both ways
if you have heard of the Harman target and it seems interesting to you, look up oratory eq settings and he has settings for this headphone for both peace and the rme unit which also works on the monoprice, i tried the harman target and preferd the bass but the changes to the mids i did not like and prefer the mids unchanged on this headphone and the treble still seemed a bit much on modern types of music that i listen too
if you want to try my settings which i prefer over everything i found so far, they are the following
i have a low shelf bass filter of +6 db at 100hz which is basically the same as what the Harman target is for bass according to what oratory measured/made
and for treble i have the following
peakfilter of -4 db with a q value of 2 at 7000hz
and another peakfilter of -4 db with a q value of 2 at 10000hz
and that makes the treble seem better for more modern types of music like edm, pop, hip hop and so on
please let me know if you tried this and what you think as i have not shared these settings yet and i am curious as to what others think of it
