Sennheiser HD800 S Impressions Thread (read first post for summary)
Jul 24, 2019 at 12:00 PM Post #4,801 of 8,771
Hi everybody. I’ve searched this thread but couldn’t find an answer. I’m looking for a short (1.25m) balanced 2.5mm cable for my HD800S for use with my Plenue D2 balanced out. I did find a cable from a U.K. shop but they don’t accept turkish credit cards. Could you guys recommend me a cable like this? Would be much appreciated. Thanks in advance.
Jul 24, 2019 at 12:25 PM Post #4,802 of 8,771
Just search for HD800 on Aliexpress and you'll get plenty of options :)
Jul 24, 2019 at 12:41 PM Post #4,803 of 8,771
Thanks for the reply and the tip. Made a quick search on Aliexpress and found a bunch. Thanks again.
Jul 26, 2019 at 11:58 PM Post #4,808 of 8,771
A small warning to anybody getting the (misodiko Replacement Ear Pads)
these pads are really easy to install but very very hard to uninstall ,, i had to destroy on of them to get it out of my HD800S ,,
so be very careful before installing them ,, sound wise , i didnt like it ,, it make the sound hollow and more harsh , mid bass disappear,
but nonetheless it could work for others , its all about preference
Jul 27, 2019 at 6:25 AM Post #4,809 of 8,771
The trick to remove them is to get one corner to lift a little bit and then weirdly you start rotating the earpad and it should then slide off.
That info was not included in the bag that the pads came in, but it is included in the box that my dekoni elite sheep pads came in and they use the exact same frame.
So, for others, all you do is prise up a little area of the pads, then from the inside and underneath the pads, start to gently turn the whole pad and it will then start to slowly unclip itself without any force.
Shame you had to destroy them to get them off, if you get other pads, try the dekoni removal solution as it really does work.
Soundwise the misodiko pads do absolutely jack to the sound, this isn't aimed at you, but this place never ceases to amaze me with the bullschit that some folk say, next I will see somebody post that if they hold their finger up in the air, the highs will be less sharp and bright and more refined, and the bass got tighter and now I can hear the mids oh so much better.
It's hilarious reading what some folk say. No wonder audiophiles get a bad name and why this game is expensive, as we have idiots endorsing crap that just doesn't do anything.to change the sound at all.
This is how we end up with schit like this that only costs £2500.
http://www.hifiplus.com/articles/win-an-audiodesk-systeme-vinyl-cleaner-pro-worth-2525-and-more/
A machine to blow dust off a bloody record, which technically shouldn't have dust on it if you keep it in it!s dust cover jacket.
All that can be yours for only £2500.
Jul 27, 2019 at 8:34 AM Post #4,810 of 8,771
Wow that's a great essay!
It never passed from your mind that you can hear jack crap as you say and you accuse other members as idiots because they hear the sound change.
Maybe you are some kind of golden ear super guru and he have to take your thoughts and opinion as a token.
You accuse other members for their subjective opinion and then you just lay down your own subjective opinion with out any objective proof.
Great what a headphone guru you are!
Jul 27, 2019 at 9:00 AM Post #4,811 of 8,771
It never passed from your mind that you can hear jack **** as you say and you accuse other members as idiots because they hear the sound change.
Yup, and thanks for your support of my great essay.
Jul 27, 2019 at 9:20 PM Post #4,815 of 8,771
Thanks for the first part , i hope it would be helpful for others ,, second part i didn't understand ,, English is not my first language , sorry.
