Venom Snake
- Oct 30, 2016
You have no idea what you will miss. Tubes are amazing. Apart from the choices. I like to have a dac and amp of the same brand. Else my OCD-kicks in.
I do advise the Schiit Mjolnir 2 and the Schiit Gungnir (if you can afford it the multibit-variant, else the regular one does suffice)
The good thing about tubes is that you can customize the sound signature to your liking by rolling different tubes to your hearts content so I second that option.
Now to update on my experience I did receive my Schiit Valhalla 2 / Bifrost Multi-bit with PYST RCA and USB cables so here are my initial impressions:
Compared to my SupremeFX Hi-Fi DAC there is an improvement but it is subtle, the Soundstage seems wider but that's about it really. Am I doing something wrong?
It might be that my setup is not properly connected so I would like your input guys please correct me if I'm doing something wrong:
I connected the HD800S to Valhalla 2 6.35 mm input > connected RCA cables (Red color in R and black color in L) in Valhalla 2 RCA output to Bifrost RCA input > set valhalla gain to Hi > connected the PYST USB 2.0 cables from my Bifrost USB port to my PC USB 2.0 port (does it make a difference if I plugged the USB at my PC's USB 3.0 port?) > Windows 10 downloaded drivers automatically (called Schiit USB Gen 2).
I tried listening to some classical music but I didn't get the famous instrument separation and clarity I keep reading about they sounded like any other headphones I tried (with the exception of wider soundstage) and then I tried to listen to my one of my favourite tracks "bastille - of the night" and it was harsh and vocal had stiffness (i.e. Rhythmsssssss instead of smooth rhythms).
So there is definitely something wrong with my setup (either the connection or I didn't secure the tubes correctly) or I was just putting high expectations out my amp/dac combo.
I'll post again after letting the amp/dac to break-in and update my impressions.
