RiseFall123
How many hours of break in did you do with the 660 to make it “sing” correctly?
Use force on the fully extended metal parts.How do you loose the headband:
1) by the centre of the headband
2) using a force on the metal parts, putting them out fully
What is the safer and correct method?
CN you please compare both the hd600 and 660? Wich sound Fuller/thinner? Wich hás more bass and punch?I returned my HD 660s early this week and I'm keeping the HD 600 instead.
HD660S feels as a more modern headphone, that's obvious for me. It delivers a very clear sound but it's hard to describe, I get tired too soon listening to them. I really wanted to like them... But after a couple of weeks comparing to the HD 600 bought for less than 200€ I decided to choose the 600, the price is less than half and the quality is still superb.
I will somehow try again with modern sennheiser with the future HD58X.
Thank you
This is no problem. I did this to the HD650 and the HD660S, it works just fine. And you still can slide the extensions back in.What do you think about this from a review:
“I've heard others suggest to bend the metal headband extensions; I don't like this idea as the shape of the metal extensions are set to slide into pockets in the headband and I think it's best to let them retain their proper shape.”.
Give them 100 hours....and still again, how these headphones (660) are sensitive to burn in?
Have you ever heard a Beyer T90?Hd800 are overly bright, one of the brightest headphones on the market,
Have you ever heard a Beyer T90?![]()
Thank you
But would you say that being brighter, the hd660 also sound thinner than the hd600?The bass and overall the detail and definition is better with 660S. But it is too bright for my taste. Just that. As other said it would be a keeper with a lower price.
600 is a magical balance for me. Clearer and brighter than 650, but in the right amount... For me.
The price of the future 58X makes more sense to me to have another sound signature.
The 660S is great but I suggest to try first or buy it with return possibility. Just in case.
