MattTCG
- Jan 22, 2012
The STX actually has a pretty decent dac. It'll be fine for now.
yeah it'll be lovely to audition the headset with pair of many combination since i see many recommendation i really hope we could just waltz into some store and get a honest professional advice without them bugging me to buy the most expensive one.
and don't throw me stone for this question, but is the source mean the format of the song? speaking of format i've tried 192 khz lossless format and compared it with 44.1 khz, not much difference. but saying that without an amp might not mean much. Seen many articles about amp and impedance of a headphone. what exactly amp does? if i'm not mistaken it open up the dynamic range of the signal across the spectrum? how can i choose an amp suited to my needs or its purely subjective and not based on technical data?
On the topics of DACs. Is there a way to use my ASUS Xonar DG (the built in DAC) for the mean time with the Schiit Valhalla I recently purchased?
If not, what do I need to do to use iPods, Smartphones (Galaxy Nexus for example), etc with the Schiit Valhalla?
After reading these last few pages on this thread, I'm beginning to wonder if I've made a wrong choice choosing the Violectric V100. The curious little hamster in me wants to now try the schiit amps which were second on my list. Any particular reason why violectric doesn't get mentioned more often?
I concur with BobJS, so much to learn from this. Right now I don't think I can handle rolling tubes and/or accidentally breaking tubes in amps.
Soon enough though when I have more stable income
I think you have to run the 'pointee' or 'trinty' kernel for usb support under jellybean unless they've added support after 4.1
I doesn't work for all DAC's its mainly geared up for the usb dock, the fiio E17 and quite a few others require the kernels I mentioned I looked into it as I have a Nexus 7
http://www.head-fi.org/t/627459/use-a-standard-usb-dac-with-a-nexus-7-step-by-step-guide
Can anyone recommend a cheap aftermarket cable for HD 650 which has a 4 pin XLR?
Whats your definition of "cheap"? I don't think anyone sells one mass produced so custom is gonna be the way to go, which is not that cheap.
